Old 06-13-2016, 10:47 AM   #1
nuke82
nuke82's Avatar
67-72 SBC Headers That Don't Drop Below the Frame - Show Me Your Pics!
So I've been searching the site for information on header ground clearance. I found a lot of info/pictures for BBC but not much on first gen SBC. I currently have Hedman 69097 headers and they drop all the way below the frame. I know I am probably looking at midlength headers if I want them to tuck, but I wanted to see if anyone had any creative solutions or if there is an off-the-shelf header that tucks.
Does anyone have full length or tri-y headers on their 67-72 trucks with a 1st Gen SBC that do not drop below the frame? Pics would be awesome.
72 Chevy C-10 w/ 67 front clip
355 ci Vortec
79 Lincoln Versailles 9" rear end, 390 gears
700R4 tranny
McGaughy's 2.5" Front Drop
Fatbar 4-Link
nuke82 is offline   Reply With Quote
Old 06-13-2016, 11:21 AM   #2
Boyd67
Boyd67's Avatar
Re: 67-72 SBC Headers That Don't Drop Below the Frame - Show Me Your Pics!
If you scroll down and click on details. Says allows exhaust to be tucked up for maximum ground clearance.
http://www.hedman.com/site/?d=118&dt...tart=5&limit=5
Boyd
-67' C10 SWB FLEETSIDE LS 5.3 4 speed muncie
Boyd67 is offline   Reply With Quote
Old 06-13-2016, 04:34 PM   #3
SHANE 73Z
nuke,
Check out my build thread (link at bottom)
I am running a pair of old Thorley 375y Tri-Ys. They were originally intended for a second gen Camaro.
I don't know who has the rights to this design, but you can try Thorley, Headers by Doug, or Stans headers. I think they all still build this same basic header.
Shane
68 Short Wide Build Thread here: http://67-72chevytrucks.com/vboard/s...d.php?t=534759
SHANE 73Z is offline   Reply With Quote
Old 06-13-2016, 08:30 PM   #4
nuke82
nuke82's Avatar
Thanks Shane, that's exactly what I was looking for. Looks like those 375Y's are for Chevelle's too, I know Chevelle headers are popular for the BBC C-10's. All three companies headers for the Chevelle look the same except Stan's uses ball and socket collectors.
This is a pic of my Hedman 69090 headers.
355 ci Vortec
700R4 tranny
Fatbar 4-Link
Old 06-13-2016, 11:16 PM   #5
I run Headman TorqSteps on my '72 K2500 and the are totally in the frame
Old 06-14-2016, 07:52 AM   #6
TCCGRIZ
Do you have more pics of your headers please and are they ceramic coated , thanks
TCCGRIZ is offline   Reply With Quote
Old 06-14-2016, 09:37 AM   #7
c10ss69
c10ss69's Avatar
What are you guys doing about the shift linkage on a column shift truck being in the path of the exhaust with the shorter headers? Anyone with pics?
Mike
c10ss69 is offline   Reply With Quote
Old 06-14-2016, 12:48 PM   #8
nuke82
nuke82's Avatar
I eliminated the column shifter with a B&M truck Megashifter.
I Iike those Hedman torksteps too, wish I had ordered them in the first place! Huge difference between their torksteps and traditional long tubes.
355 ci Vortec
700R4 tranny
Fatbar 4-Link
Old 06-14-2016, 02:04 PM   #9
Sean1985
Sean1985's Avatar
I got a pair of Sanderson headers from ece. Ceramic coated. I used a lokar shifter.
Sean1985 is offline   Reply With Quote
Old 06-14-2016, 04:53 PM   #10
nuke82
nuke82's Avatar
@Special-K, are those P/N 69094?
355 ci Vortec
700R4 tranny
Fatbar 4-Link
Old 06-14-2016, 05:02 PM   #11
rharp
I used Hedman midlength #69010. The flanges are just a shade lower than the bell housing.
1969 Chevy CST/10 396, PS, PB, A/C
rharp is offline   Reply With Quote
Old 06-14-2016, 10:49 PM   #12
I bought them uncoated in '04 and had them done in flat black. I didn't realize that was just the primer. Still this picture was last fall. I have them off now for a valve job and took a wire wheel to them to spray with VHT. If I had the money I'd blast and have coated again, but all the way. I can take pictures with them off. They are a tight little package for full length. I'd like to try to fit them on a 2wd while they are off. They say the 4wd ones sit higher. Great for the off road aspect, but seems odd the lower 2wds wouldn't be this high, if none are
Old 06-15-2016, 09:13 AM   #13
TCCGRIZ
Thanks for the reply , I am looking at the Headmans for my 72K10. Just want to make sure I have enough room where my slave cylinder is for the hydraulic clutch.
Old 06-15-2016, 10:28 AM   #14
Mike C
Mike C's Avatar
Because of how the cross members are positioned on the 2x4 vs 4x4 trucks and how the engine is further forward on the 2x4 trucks and then the trans linkage, it's much easier to tuck the 4 wheel drive header. On my Jimmy the Heddmans that are/were on it appear to be the same as Special K's. They appear to be the same as the 63-82 Corvette and have a #1 cylinder pipe that is at a steeper angle than the Chevelle headers and shorter overall height to work with the rearward engine position.
That's why the 2x4 exhaust hangs lower than the 4x4 and why the solution has been to go to car headers and the 2nd gen Camaro and Chevelle headers appear to be the best fit.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 06-15-2016, 05:16 PM   #15
Redline novdog
Redline novdog's Avatar
Good Info!!!! Thanks all!!!
It builds on my intelligence when I make a mistake, Boy am I building on it!
'67 C-10,'70 Nova SS
Redline novdog is offline   Reply With Quote
Old 06-16-2016, 12:41 AM   #16
heathbirkendahl
I have set of these with ceramic coating. Holding up very well.
https://www.sandersonheaders.com
1971 C/10 - Orange & White
2009 GMC 1500 - Lowered 3/4 22' KMC Slides
heathbirkendahl is offline   Reply With Quote
Old 09-10-2016, 12:18 AM   #17
nuke82
nuke82's Avatar
So after a lot of thinking and great feedback here (a big thank you to you guys) I went with the Stan's tri-y headers for a Chevelle. Just installed them and they fit like a glove! The passenger side came a little close to the frame but caused no issues. In one of the pics you can see how much lower the Headmans were (on the far side of the truck)
355 ci Vortec
700R4 tranny
Fatbar 4-Link
Old 09-10-2016, 06:15 AM   #18
7tee
7tee's Avatar
Looks great and I was wondering how they will work out on the drivers (left) side around the z-bar for a clutch... Ed
1970 C/10 350/T5 SWB stepper...
1979 Corvette 350/Auto T-top...
2010 Acura RL...
2015 2500HD Z-71 Silverado...
7tee is offline   Reply With Quote
Old 09-13-2016, 09:25 AM   #19
SHANE 73Z
7Tee,
My truck (sbc with v8 frame mounts) with the same basic headers fit around the clutch linkage. My only issue was the swing for the upper arm. I had to tweak it outboard a bit to clear.
I am sure there are pics in my build thread.
Shane
