Old 01-10-2016, 01:48 AM   #1026
sduckworth13
sduckworth13's Avatar
Re: My '67 Fleetside C10 renew
That motor sounds awesome, looks like alot of fun too.
Scott
sduckworth13 is offline   Reply With Quote
Old 01-11-2016, 09:15 PM   #1027
jlsanborn
jlsanborn's Avatar
Originally Posted by Captainfab View Post
Runs and sounds really good
Is that the same engine he built back in September?
Yup, still running strong John
He did a really good job on this. Not a lot of $$$ invested. Rebuilder pistons (theoretically 10.2:1 after decking), reground cam, used roller lifters and used marine style timing set. We "worked" an old HEI and a Q-Jet. He did shell out for an Air-Gap, 8mm LS valves and hardware for his 906 heads, and some fancy Comp 1.6 rockers. I'm sure it's a 400hp dealio. REALLY needs a stall.
'77 K30 3+3 - "The Crummy"
http://67-72chevytrucks.com/vboard/s...d.php?t=640134
'67 C10 L/SWB - Soon to be daily driver!
http://67-72chevytrucks.com/vboard/s...d.php?t=471776
jlsanborn is offline   Reply With Quote
Old 01-12-2016, 09:25 AM   #1028
mcbassin
Still Learning
mcbassin's Avatar
Killer rip in the snow. That puppy sounds strong! Nice work John.
Old 01-12-2016, 11:13 AM   #1029
Bomp
Bomp's Avatar
Healthy with a deep throaty sound. Very Respectable.
Bomp is offline   Reply With Quote
Old 01-14-2016, 11:03 AM   #1030
butternut1972
butternut1972's Avatar
[QUOTE=jlsanborn;7441087]Thanks man! How's the stepper?
Stepper is good, just waiting for summer. It has taken a back seat the last few years to my sons racing. Feel kinda bad for it..
1972 GMC (PROJECT LONG OVERDUE)
1998 SWB 4WD
butternut1972 is offline   Reply With Quote
Old 04-25-2016, 10:37 PM   #1031
kehstr
kehstr's Avatar
This is a cool truck! any updates?
kehstr is offline   Reply With Quote
Old 04-26-2016, 01:04 PM   #1032
Low Elco
Yeah! What he said!
Low Elco is offline   Reply With Quote
Old 04-26-2016, 03:52 PM   #1033
88Stanger
88Stanger's Avatar
what they said...
88Stanger is offline   Reply With Quote
Old 04-26-2016, 06:22 PM   #1034
jlsanborn
jlsanborn's Avatar
Thanks for the bump fellas! I haven't given up. Life has had me distracted but I see the truck every single day and I'm still in love.
I sent those 52 year old heads in for the full-meal-deal and they're basically done. Have been for over a month or two. 7/16" screw in studs with guide plates, 2.02x1.60 swirl polished stainless valves (8mm LSX style), hard seats, full port and polish, unshrouded for the big valves. Trying to identify a beehive spring that will work with the cam I've picked out but draggin my feet.
Lunati Bootlegger
•Advertised Duration (Int/Exh): 284/309
•Duration @ .050 (Int/Exh): 232/244
•Gross Valve Lift (Int/Exh): .554"/.554"
•LSA/ICL: 108/104
•Valve Lash (Int/Exh): Hyd/Hyd
•RPM Range: 2800-6000
We'll be running a domed piston bout 11.0:1 CR
Old 06-13-2016, 11:23 AM   #1035
SierraMtns
SierraMtns's Avatar
Lunati Bootlegger
•LSA/ICL: 108/104
Sounds like a sweet motor. Lets see some pictures.
SierraMtns is offline   Reply With Quote
Old 06-13-2016, 01:10 PM   #1036
jlsanborn
jlsanborn's Avatar
Thanks for checking in! My heads are all done. Got some beehives from Lunati. Trying to squirrel a way a few more sheckles for pistons and rods now.
Old 06-13-2016, 01:31 PM   #1037
Low Elco
Dat's niiiiice. Knuckles still workin' there?
Old 06-14-2016, 07:51 PM   #1038
jlsanborn
jlsanborn's Avatar
Yup, he needs to bounce though. Working his tail off for not a lot of $$$ and their promise of training on machine tools has not come true. He's an expert at tear-down, hot tank and magnaflux. He did land a part time deal with one of their customers, ebay seller hpenginesuperstore, which might grow into something better for him.
Old 06-14-2016, 08:13 PM   #1039
Vic1947
Vic1947's Avatar
Heads look great, John. Did they do a before and after on a flow bench?
Victor
57 Chevy Wagon - California Dreamin'"Mecum'd" 9/2022 Dallas, TX
Crusty Rusty Leaky Squeaky 67 Consigned 4/2019 Dresden, Germany
Maybelline - my '57 Ford 2dr Sedan "Mecum'd" 3/2016 Location unknown
Silver Streaker "Mecum'd" 4/2013 Somewhere in Texas
Vic1947 is offline   Reply With Quote
Old 06-14-2016, 08:34 PM   #1040
jlsanborn
jlsanborn's Avatar
I don't think so. They send them out to an old timer up in Sandpoint, ID along with my intake and exhaust gaskets (that didn't come back). I guess he's been doing these for quite some time. $200 for the port work. You may have noticed in the photos that they didn't un-shroud the intake valves. Boy got tired of arguing with them. They say it's unnecessary but I can't imagine they performed that step at the factory for the 2.02" valves for no reason. I might take them someplace else for that step.
Old 06-14-2016, 08:38 PM   #1041
jlsanborn
jlsanborn's Avatar
Oh, and when he did the port work he cut through some of the roofs into water jackets. Said to apply some JB Weld! The spots that got cut through were right below the rocker stud bosses, so the shop drilled and tapped 7/16" down through the stud bores and installed short screws with epoxy and pressure tested them. Bit of a nightmare.
Old 06-14-2016, 09:11 PM   #1042
Vic1947
Vic1947's Avatar
Sounds like it! Hitting water can happen when you're flying blind without sonic testing, but I'm surprised an experienced port man had that problem. I sure wouldn't trust JB Weld alone to fix it. Sounds like the shop applied a suitable patch though. Cast iron heads can be opened up more than aluminum because they tolerate a thinner wall thickness, but man, it's so much easier to fix holes in aluminum.
Victor
Old 06-14-2016, 09:55 PM   #1043
Low Elco
Oy Vey.
Old 06-14-2016, 11:35 PM   #1044
Captainfab
60-66 Nut
I thought there was someone in Spokane doing port work. When my son had his 4.3 built at S&J I thought they sent the heads to someone in Spokane and had them ported.
Old 06-15-2016, 09:56 AM   #1045
jlsanborn
jlsanborn's Avatar
I haven't come across anyone local. I know you asked to find out who this guy is. When I brought the heads back to the shop to show them the holes I asked. All I could get out of them was "Sandpoint" and that he was a quirky old codger or some sh!t like that.
Old 06-15-2016, 12:32 PM   #1046
Low Elco
Sandpoint! 'Cause he always hits water! BAHAHAHAHAHAHAHAHA! Jeez, I crack myself up.
Old 06-16-2016, 12:38 AM   #1047
Captainfab
60-66 Nut
It sounds like the 'quirky old codger' maybe should hang up his die grinder if he's grinding into the water jackets.
Old 07-08-2016, 11:15 PM   #1048
jlsanborn
jlsanborn's Avatar
Nothing to report in terms of "work" but I have been squirreling some moolah. How about some forged domes for 6" rods!? Will have to turn some of the domes off to bring it back down to 11:1. Also nabbed some Lunati stud girdles and a Melling pump. Boy sprang for the 7/16" rocker arm studs and guide plates. Another grandy and I'll be assembling a bad-ass short block Mouse. Another five hunny after that and I'll be long block. Another thou after that and it'll be nearly turn-key!
Old 07-09-2016, 12:24 PM   #1049
Vic1947
Vic1947's Avatar
All I see is bubble wrap, but what you're describing sounds awesome, John!
Victor
Old 07-09-2016, 01:05 PM   #1050
jlsanborn
jlsanborn's Avatar
Weird...
295/50-15, 327, butternut yellow, dog dish, muncie m20
