Old 06-15-2016, 09:24 PM   #26
Frugalmeyer
Re: 1972 Blazer 4WD to 2WD conversion in Texas.
New carrier bearings, pinion bearings and seal, axle bearings and seals, new lines, studs, all hardware and drums. Clean and paint.
Frugalmeyer is offline   Reply With Quote
Old 06-15-2016, 09:26 PM   #27
Frugalmeyer
gringoloco
I'll get some measurements with photos when the frame comes back from blast and paint.
Old 06-20-2016, 10:36 PM   #28
Frugalmeyer
Inside firewall, dash and kick panels painted.
Old 06-20-2016, 11:59 PM   #29
truckster
truckster's Avatar
Nice. How did you clean up the rear axle?
truckster is offline   Reply With Quote
Old 06-21-2016, 12:16 AM   #30
Frugalmeyer
truckster
First I stripped off all brake parts and brake lines, scraped with scraper and screwdriver (for tight areas), pressure washed at car wash, had all seals and bearing replaced, wire wheeled and wire pointy thing (for tight areas), wipe down with lacquer thinner, primered and roughed up with scuff pad, painted with PPG black paint, installed all new brakes and brake lines.
Old 06-21-2016, 01:33 AM   #31
truckster
truckster's Avatar
I sandblasted mine, and it was a mess. Yours turned out really nice.
Old 06-21-2016, 09:18 AM   #32
Mike C
Mike C's Avatar
Nice work! Was a good lucking 20 foot truck when you got it, but is a real beaut now! I've contemplated a 2x4 conversion to a Blazer over the years but decided I'd scratch that itch with the '69 short step on working on now.
My 13 year old son and I are starting to refurb a '72 Jimmy 4x4 that was wrecked HARD in the front. Could use things like springs, mounts, driveshafts, etc. Shoot me a PM if you want to talk turkey on someone taking all the 4 wheel drive parts off your hands.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 06-23-2016, 01:14 AM   #33
elkniks
elkniks's Avatar
Originally Posted by truckster View Post
I know this might be taken as offensive by some, but it's really not meant to be: Why? What I mean is, why take a 4 wheel drive and make it what I would consider to be less capable? I know it's a popular conversion, but being a guy who sold his 2 wheel drive trucks and saved up to buy a 4WD Blazer I always wanted, I have a hard time understanding it. I'm not knocking it, I just would like to understand the reasoning.
And by the way, your skills look to be first-rate. It looks like a great job.
I can tell you why I did mine. I bought my Blazer about 20 years ago, fixed all the rust, put on a lot of new sheet metal, went through the whole truck. Lifted it 6" and put it on 35's. Loved it and it looked sweet. It looked so sweet that there was no way that I was going to risk damaging it off road and depending on where you live there may not be much off road even available.
The older I got the lower the truck got (pulled leaves) untill it just sat in the garage on 32's and I never drove it because the ride was horrible and it just was not that fun to drive in my opinion.
Did my conversion last year and I looooove it! Handles great and no more bounce.
NOT ONE PERSON HAS CALLED IT A BRONCO SINCE I LOWERED IT! That there is reason enough.
elkniks is offline   Reply With Quote
Old 06-23-2016, 01:33 PM   #34
Frugalmeyer
elkniks
Seaside, Ca! I was stationed at Fort Ord from 1990-1994 when it closed. Do you have a picture of your truck?
Old 06-23-2016, 01:59 PM   #35
elkniks
elkniks's Avatar
I will upload some later. Not a big picture taker. I feel kinda bad for not documenting more to share on the conversion.
When Fort Ord first closed it was kind of abandoned and not locked down yet like it is today. We used to go out there and drive around and explore. We were young and dumb then, lots of ordinance still around then I'm sure!
Old 06-25-2016, 09:44 PM   #36
Frugalmeyer
Engine is ready, will pick up when ready to install.
Old 06-29-2016, 07:20 PM   #37
Frugalmeyer
Frame and suspension parts sand blasted and painted.
Old 06-29-2016, 07:26 PM   #38
Frugalmeyer
Got the frame back and installing it under the truck.
Old 06-29-2016, 07:44 PM   #39
truckster
truckster's Avatar
Almost thou persuadest me!
Old 06-30-2016, 01:07 PM   #40
Lieferson
Lieferson's Avatar
Holy tool boxes! Jealous
Truck will look pretty darn nice when you're finished! Great progress
1970 1/2 ton 4x4 4spd Suburban
1972 K10 350/700R/205/ Sniper EFI Daily Driver Sold
1971 K5 on 35s Traded
1972 K5 3/4 ton PROJECT Sold
Lieferson is offline   Reply With Quote
Old 06-30-2016, 05:31 PM   #41
Big Block
Big Block
Big Block's Avatar
Awesome progress. Nice color.
Big Block is offline   Reply With Quote
Old 06-30-2016, 07:37 PM   #42
Frugalmeyer
Thanks for the positive feedback.
Old 07-09-2016, 02:05 PM   #43
Truckseats
Truckseats's Avatar
Nice!
Truckseats is offline   Reply With Quote
Old 07-09-2016, 02:48 PM   #44
Frugalmeyer
Bolting up the front suspension and brake lines.
Old 07-09-2016, 02:54 PM   #45
Frugalmeyer
Fabricating fuel supply and return lines, laying out fuel filter and fuel pump, testing and welding original tank fuel filler neck on LMC tank.
Old 07-11-2016, 12:11 AM   #46
Frugalmeyer
Some parts used:
1977 C10 front cross member
1977 C10 upper and lower control arms
1977 C10 lower ball joints
1972 C10 upper ball joints
1972 C10 tie rods, idler arm, pitman arm and center link
1972 C10 rotors, drop spindles and calipers
1972 C10 tilt column
1986 C10 gearbox, power steering hoses and steering coupler
Old 07-12-2016, 06:21 PM   #47
Frugalmeyer
Installing rear suspension.
Old 07-13-2016, 11:28 AM   #48
gringoloco
A guy with a truck
gringoloco's Avatar
Super clean!
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 07-25-2016, 08:11 PM   #49
Frugalmeyer
Installed engine checked clearances - removed motor and trimmed transmission bell housing ears, bent steel fuel lines at frame, removed stock oil pan and installed HMMWV oil pan. Black pan is stock and silver pan is HMMWV. Reinstalled engine.
Old 07-25-2016, 08:15 PM   #50
Frugalmeyer
Installing Vintage Air A/C bracket, power steering pump and power steering lines.
