![]() Join Date: Jun 2006
So as is in my usual way I found something else I plan to change from stock. I need lengths of SS rods threaded on the ends only that are around four feet long. I also need a few shorter ones too.
So what these are for is to do away with the stock hood springs and latch and build hood prop rods like the Willys use except two, one for each side. The latches themselves will be revealed after the truck is done since again I'm doing something different ![]() Where can I get them? Should I try Grainger? 3/8"
Custom Painter/Restoration Specialist 1965 GMC 3/4 Ton LB SOLD? 1964 Chevy El Camino in full restoration 1991 Chevy S10 288K+ miles 2nd Owner SOLD 2020 RAM 1500 Warlock |
Moderator
![]() ![]() Join Date: Aug 2011
Re: Stainless Rod
or McMaster-Carr.
Re: Stainless Rod
Never Ending Projects
Re: Stainless Rod
Buy SS rod and use a die and tap them to your thread size.
. 1965 C10 Panel, ![]() 1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD 1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD We were given two ears and one mouth for a reason... listen twice as much and speak half as often... |
#5 | |
Re: Stainless Rod
ron |
