Old 06-18-2016, 11:33 AM   #1
Gunnin4ya
Installing fuse block
Just got around to starting to install the wiring in my 65 and noticed that the handle for the vent hits the fuse block. Has anyone else ran into this problem when installing an American Autowire kit? And if so what did you do to fix it? I just got all new seal put in and rebuild the vents so I would rather not delete them. Thanks in advance.
Gunnin4ya is offline   Reply With Quote
Old 06-18-2016, 09:54 PM   #2
racecougar
racecougar's Avatar
Re: Installing fuse block
Could you post up a photo of the interference? With the vent fully closed, the handle should be well aft of the fuse panel.
Rod @ AzzKicker Cars
1965 C10 SWB - Build Thread
racecougar is offline   Reply With Quote
Old 06-18-2016, 10:36 PM   #3
Gunnin4ya
Here is one open and one almost closed.
Old 06-19-2016, 07:50 AM   #4
Shift your fuse box up and to the right some. The original boxes had a lot less to them than the newer/upgrade ones do.
Old 06-19-2016, 04:33 PM   #5
racecougar
racecougar's Avatar
The handle for the vent should have a bit of a bend in it to provide clearance at the fuse block.
Old 06-20-2016, 01:55 AM   #6
Kenfuzed
Kenfuzed's Avatar
I actually noticed the same thing with my stock fuse block. Maybe the PO of my truck bent the lever the wrong way because it seems way too close to the fuses.
1966 C10 Short Fleetside
1988 Sportster, 2008 Street Glide
Ken's 1966 C10 build "Red Ale"
Follow on Instgram: @cv_performance
https://instagram.com/cv_performance
Harley Performance Parts: CV Performance (Harley related)
Enjoying the ride!
Kenfuzed is offline   Reply With Quote
Old 06-20-2016, 08:39 AM   #7
Gunnin4ya
I may end up drilling the rivets out and flipping it over and installing new rivets.Was just hoping that there was a quick fix I was missing
Old 06-20-2016, 11:54 PM   #8
Captainfab
60-66 Nut
I think I would just put a little bend in the vent arm. Do the other side also so they match.
Old 06-21-2016, 01:46 PM   #9
ninetoestroy
Looks like you have enough room to bend the vent handle forward enough to miss the fuse block or even bend it up to clear.
ninetoestroy is offline   Reply With Quote
Old 09-17-2016, 10:21 AM   #10
Heater63
Heater63's Avatar
Bump,
YES! exact same problem here. Mine is the classic upgrade kit, looks like yours is too. So much for a kit designed for these specific years!
Did you talk to AAW?
I will probably just bend my arm enough to clear
292 + TKO500
Heater63 is offline   Reply With Quote
Old 09-18-2016, 05:55 PM   #11
racecougar
racecougar's Avatar
Just dealt with this myself. Before on the left, after on the right.
Old 09-18-2016, 09:02 PM   #12
Gunnin4ya
I thought about drilling out the rivets and flipping it over. Yours looks great. What did you do to get it to clear?
Old 09-18-2016, 10:14 PM   #13
Heater63
Heater63's Avatar
LOVE the slicks Cougar!
I cut my shaft, welded on a downturn. Will post a pic soon.
292 + TKO500
Old 09-18-2016, 11:16 PM   #14
racecougar
racecougar's Avatar
Used the torch to heat it at the bend, then persuaded it into a lower position. This was done out of the truck of course, in the vise. The fifty year old steel showed some minor cracking after bending it, so I ran a good, hot bead on it, then smoothed it back down with the Roloc and shot some paint on it. Excepting those seeing this thread, nobody will ever know it has been modified.
Thanks!
Old 09-19-2016, 09:17 AM   #15
earl84
Had to bend mine as well. Fully functional with a slight bend.
earl84 is offline   Reply With Quote
Old 09-19-2016, 01:49 PM   #16
AnlaufJohn
I wonder if the previous users of that truck used their foot to open and close the vent door?
We have some switches at work that are designed for reversing the movement of a chain hoist. The handle keeps getting broken, as 1 person uses their foot on the switch to reverse the action.
Eugene, Oregon
Lucy's Limousine
1966 C-10 LWB
283 w/ 2bbl, OE carb and dist.
4 spd (granny 1st) w/ 3.73 rear end
AnlaufJohn is offline   Reply With Quote
Old 09-19-2016, 02:25 PM   #17
racecougar
racecougar's Avatar
That bend was put there from the factory.
Old 09-20-2016, 04:01 PM   #18
Heater63
Heater63's Avatar
I think we've all used our feet to open and close, but I don't think you could bend that rod, the door would tear out of the frame first.
Here is a pic of mine installed. I cut off the loop and welded on a turn down rod.
292 + TKO500
Old 09-20-2016, 04:12 PM   #19
Gunnin4ya
Looks good
