06-18-2016, 08:16 PM | #1 |
Good posi diff gearing?
So after my car shows today, I was inspired to really start thinking about what I'd like done with the truck. The one thing that I cannot find good advice on is a good gear ratio for a posi diff. I still want the truck to have some towing power, but I'd love to still be able to moonlight as a proper street machine. What would be best?
Posted via Mobile Device |
06-18-2016, 08:29 PM | #2 |
Moderator
Re: Good posi diff gearing?
that depends on much, tire size, transmission gearing and how many RPM's your looking for at highway speed. Add you info here and get an idea of what you want: http://www.dennysdriveshaft.com/pote...alculator.html
There are quite a few sites like that online.
06-18-2016, 09:10 PM | #3 | |
06-18-2016, 09:39 PM | #4 |
You'll have a far easier time finding a 3.73:1 ratio.
06-18-2016, 10:49 PM | #5 |
06-19-2016, 12:17 AM | #6 |
60-66 Nut
I would suggest taking a look to see what gears you have now. Your truck could very likely already have 3.73's. That was the most common gear ratio.
06-19-2016, 12:08 PM | #7 | |
06-19-2016, 01:58 PM | #8 |
With a c20 you will have the eaton rear axle and the only gears are 4.10 and 4.57.
Current projects: 1966 Chevy Custom PS PB A/C BBW 283 v8 3 speed OD 1966 GMC Long Step 1966 GMC 3/4 ton Custom PS PB Sport trim 351 v6 1966 GMC 3/4 ton 4x4 Custom PB 305 v6 np435 1960 GMC Custom 1968 GMC 3/4 ton 4x4 Short Bed 1962 K20 Tow truck 1961 GMC Extended Suburban Panel and a few more |
06-19-2016, 02:12 PM | #9 | |
06-19-2016, 02:16 PM | #10 | |
http://67-72chevytrucks.com/vboard/s...d.php?t=624445
06-20-2016, 12:07 AM | #11 |
60-66 Nut
Being a C20 makes a BIG difference. There are no gears or new posi units available for the Eaton HO52/72. In fact bearings and seals may be difficult to find and $$ when you do. Your best option is to change the entire differential as shown in the link as Classic v6 GMC posted.
