Old 06-20-2016, 08:58 PM   #1
jskeezy84
did I ruin the windshield?
I got the windshield out today and while trying to remove the weather stripping and all the gunk I decided to use thinner. After a few seconds I noticed that some of the glue from the weather stripping had worked its way between the two panes of glass. Right now it would be fine because new weather stripping would cover this. My concern is will the paint thinner continue to spread and work it's way further down?
jskeezy84 is offline   Reply With Quote
Old 06-21-2016, 12:53 AM   #2
chevy_mike
Never Ending Projects
chevy_mike's Avatar
Re: did I ruin the windshield?
Paint thinner tends to evaporate fairly quickly so it's likely you will be fine.
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 06-21-2016, 08:17 AM   #3
nhr3
nhr3's Avatar
The problem would be moisture getting in between the layers and causing more delamination due to possible freezing and cooking in the sun. Minimum I would seal the edges with silicone. A windshield is only about $200 so you might want to consider that route also.
65 C10 Short bed, Fleetside, small back window
Build thread - http://67-72chevytrucks.com/vboard/s...d.php?t=619304
nhr3 is offline   Reply With Quote
Old 06-21-2016, 11:44 AM   #4
jskeezy84
how is fitment on a new windshield? im in the process of redoing the patch panels above the windshield.
Old 06-21-2016, 02:40 PM   #5
nhr3
nhr3's Avatar
The new windshield fit just fine/. For I believe $225 i had the local shop come out and install it in my shop. At no extra cost he also installed my small back window slider. I was there for the whole process and very much appreciated not having to do it myself. I have the custom cab with the Chrome strip in the seal. Again I am very pleased and even though I did everything else on my truck this was a good one to farm out.
Old 06-21-2016, 07:06 PM   #6
jskeezy84
thats not bad. I figure when the time comes to put the glass back in I'll pay someone. I dont want to put all that effort into a cab just to have it leak.
