Old 06-21-2016, 11:59 AM   #1
olive drab
olive drab's Avatar
Conversion u-joints?
I have a 1/2 ton 87 that I put 3/4 ton axles under from a 91 burb. The 3/4 ton axles take a larger u-joint but my 1/2 ton uses a smaller u joint. I talked with a few guys at work and they said spicer makes a conversion u-joint? Any help is much appreciated
olive drab is offline   Reply With Quote
Old 06-21-2016, 07:36 PM   #2
kwmech
Re: Conversion u-joints?
http://www.ebay.com/itm/Dana-Spicer-...-/141548362648
Old 06-22-2016, 02:09 AM   #3
andrewmp6
They make them in a lot of sizes,Its best to figure out what two sizes u joints you need and go to any parts store.Theres something that will help http://www.fourwheeler.com/how-to/13.../photo-02.html
Old 06-22-2016, 06:45 AM   #4
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
Denny's driveshaft has lots of conversion joints. The last conversion joint I used, was the GM3R to 1350, O'riely's had it on the shelf. You will probably need the same, have them cross reference 2-1153.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs
1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX
1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears
1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now.....
1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone.
1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed.
1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm
JIMs70GMC is offline   Reply With Quote
Old 06-22-2016, 05:30 PM   #5
I bught one for the same scenario from NAPA off the shelf when I put the 14-bolt SF from my '91 V2500 Suburban under my '85 Jimmy. I was going to shorten the Suburban driveshaft once I swapped the 4L80E in, but decided to stay with the 700r4 since it worked fine. The amazing thing is, with a 4" lift I installed at the same time, the Jimmy driveshaft was the perfect length using the 9.5" 14-bolt. Who'da knew? Just too dang easy, these GMs are
Old 06-24-2016, 08:37 AM   #6
olive drab
olive drab's Avatar
Thanks for all the help guys. Im goin to get some measurements this weekend and see if I cant find one!
Old 06-24-2016, 10:09 AM   #7
sixnineK5
Try moog 348.
sixnineK5 is offline   Reply With Quote
Old 07-14-2016, 11:57 AM   #8
olive drab
olive drab's Avatar
Originally Posted by sixnineK5 View Post
Try moog 348.
I picked up a moog 348 a couple days ago and think this is exactly what I need. 1310 to a 1350 u-joint. Thank yall fer the help
