Old 07-04-2016, 07:56 PM   #1
Mrturner1
Drum type pop from exhaust
So I just put in a new MSD pro billet HEI and I fired the truck up and it runs kindof rough and has this sound from the exhaust like somebody hitting a drum about once one or two times per second. What is that? It's not really a pop, but it's definetly coming from the exhaust.
Mrturner1 is offline   Reply With Quote
Old 07-04-2016, 08:04 PM   #2
Mrturner1
Re: Drum type pop from exhaust
I put the distributor back in exactly like I took the old one out. Should I just start from scratch and pull the distributor and set it up at TDC?
Old 07-04-2016, 08:25 PM   #3
firedemon
sounds like the timing is off it runs so cant be that bad try turning distributor somewhere between 4 and 10 deg before with no vac to the advance
firedemon is offline   Reply With Quote
Old 07-04-2016, 09:13 PM   #4
garyd1961
Check the firing order. Just to be sure, I've seen experienced mechanics get wires crossed.
How is it running other than the sound?
Is the distributer the only thing you changed?
garyd1961 is offline   Reply With Quote
Old 07-04-2016, 09:42 PM   #5
Grumpy old man
Grumpy old man's Avatar
Is it a drumming noise or a knocking noise ?
Old 07-04-2016, 09:45 PM   #6
davepl
davepl's Avatar
Pair of plug wires reversed? Check them.
Off by one? Does significantly advancing or retarding improve it?
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 07-04-2016, 10:11 PM   #7
Mrturner1
Just a pop kinda noise, I think I dropped the distributor in a notch or two off again. I don't get how I do that except that the oil pump drive slot gets turned a bit when I take out the old distributor. I always put it right back, and I thought it wouldn't drop all the way if it was off.
Old 07-05-2016, 06:11 AM   #8
Mrturner1
Off by one! lol dangit that's twice in a week!
