Old 07-06-2016, 10:27 AM   #1
zach_carver
zach_carver's Avatar
Buddy Bucket owners step inside..
How have you guys got the seats back far enough against the cab? and Why does my buddy bucket seats seem to sit straight up and down? Im very crowded in my truck since Ive added these seats. They are beautiful been recovered and all, but I cant hardly stand to ride very long in them due to this. Thanks for any help..
1965 C10 LS2/4l70, WHITE, 5/7 DROP
LINK TO SUPER SNOOPY C10 BUILD---> http://67-72chevytrucks.com/vboard/s...d.php?t=689283
1977 C10 SILVERADO HAWAIIAN BLUE, 5/5" DROP, LS6/4L80E
1976 CHEVY K5, 350/350, YUBA GOLD/SADDLE
zach_carver is offline   Reply With Quote
Old 07-06-2016, 12:26 PM   #2
flashed
Re: Buddy Bucket owners step inside..
Got any pics of them installed ,I have them in my 72 and I love them .
flashed is offline   Reply With Quote
Old 07-06-2016, 02:00 PM   #3
ms2335
ms2335's Avatar
the floors are different in the 60-66 than the 67-72, event though mine bolted up no problems they where straight up. I shimmed the front of mine about an inch to inch and half and sets fine. When I reinstall I think I am going to modify the frame to compensate for the difference.
65 Chevy C10 Short Fleet BBW 6.0L/4l80E
68 Chevy C10 SWB 6.0L/4L80E
84 Chevy C10 SWB 5.3/4l60E QA1 Suspension
ms2335 is offline   Reply With Quote
Old 07-06-2016, 03:11 PM   #4
zach_carver
Yea I have pics just not uploaded to photo bucket yet.. I guess I may need to look into shimming or something as well. I love them except how uncomfortable they are. My old bench seat was wore out and all but atleast it was comfortable. I have a big gap between the back of the seat and the cab probably inches. It also bolted right up into the factory seat holes.
Old 07-06-2016, 03:13 PM   #5
MisterC
MisterC's Avatar
Here's the only shot I have of mine that gives you an idea. These are '66 GMC buddies so they fit perfectly.
Poor and content is Rich...and Rich enough! - William Shakespeare
1966 C10 Custom Cab "Luigi"
Big Window - SWB Fleetside
350 V-8 - Powerglide
My not so much a build thread as a "Slow Progression Thread":http://67-72chevytrucks.com/vboard/s...d.php?t=486894
MisterC is offline   Reply With Quote
Old 07-06-2016, 03:21 PM   #6
ms2335
ms2335's Avatar
I had an extra hole on the seats itself where it bolts to the frame that allowed me to move mine back some. mine set fine after shimming the fronts. felt like your where going to slide out of them before. Mine was out of a 67
Old 07-06-2016, 03:22 PM   #7
zach_carver
Mister C how were you able to get them against cab like that? Did you just move the entire seat back and drill new holes? Yes mine feel like there dumping me out in the floor.
Old 07-06-2016, 06:36 PM   #8
MisterC
MisterC's Avatar
No. I simply bolted them into the original holes. My seats were sold as dealer options on the '66 GMC trucks. You can tell because my center section is almost full height, as opposed to the center section on the '67 and later models. I've compared my base to that of the later models and they look the same. The angle must be in the floor contour or the seat mechanisms themselves.
Old 07-06-2016, 09:54 PM   #9
Classic v6 GMC's
Classic v6 GMC's's Avatar
This pic might help. The top corners of the seats rub on the back corners of the cab. They are the same as MisterC's seats and came factory in my dad 1966 gmc.
Current projects: 1966 Chevy Custom PS PB A/C BBW 283 v8 3 speed OD
1966 GMC Long Step
1966 GMC 3/4 ton Custom PS PB Sport trim 351 v6
1966 GMC 3/4 ton 4x4 Custom PB 305 v6 np435
1960 GMC Custom
1968 GMC 3/4 ton 4x4 Short Bed
1962 K20 Tow truck
1961 GMC Extended Suburban Panel and a few more
Classic v6 GMC's is offline   Reply With Quote
Old 07-06-2016, 11:17 PM   #10
Joemomma1
Joemomma1's Avatar
If I remember correctly on my set there was a screw that you adjust sort of where it hinges. When it was reupholstered it got covered up so no pictures.
Joemomma1 is offline   Reply With Quote
Old 07-06-2016, 11:31 PM   #11
Brad54
Brad54's Avatar
Can any of you guys with original seats take some pictures of the seat mounts? And some measurements? In Classic's pic, it appears the front of the risers are taller than the rears.
-Brad
'61 Suburban daily driver: off the road due to 180-pound 8-pt buck!
'62 K-10 long-step project
'61 C30 Camper, aka "Valdez"
There's no cool like Old School
Brad54 is offline   Reply With Quote
Old 07-07-2016, 12:25 AM   #12
MisterC
MisterC's Avatar
Mine are out right now while I do the carpet and other upgrades. I'll get some pics with measurements for you tomorrow.
Old 07-07-2016, 07:50 AM   #13
zach_carver
Yea I believe the front is taller than the rear. I think my seat is originally out of a 67. I wouldnt think it would make it that much different. I know Im gonna have to figure something out because I cant stand to drive it for very long distance. I guess I need to check my frames and see if there are any other different holes to mount actual seat in.
Old 07-07-2016, 07:56 AM   #14
zach_carver
Hard to tell anything from these pics but this is how mine are currently sitting.
Old 07-07-2016, 08:08 AM   #15
duallyjams
duallyjams's Avatar
1965 chevy with 68 buddy buckets the back is straight
66 GMC factory buddy buckets seat is laid back and the seat frame is different
I changed the steering wheel from a big GM car as they are smaller
also you can see the center seat is different between the years
James
63 GMC V6 4speed carryall
65 chevy swb bbw V8 auto
68 K20 327/4 speed, buddy buckets
2002 GMC CC Dually Duramax
64 GMC lwb 3/4 V6 4speed SOLD
66 GMC swb bbw buddy buckets SOLD
IG duallyjams
The only thing that stays the same is constant change!
duallyjams is offline   Reply With Quote
Old 07-07-2016, 08:23 AM   #16
duallyjams
duallyjams's Avatar
buddy buckets fixes
http://67-72chevytrucks.com/vboard/s...ets+adjustment
James
IG duallyjams
Old 07-07-2016, 08:23 AM   #17
zach_carver
Originally Posted by duallyjams View Post
Thanks man!
