Old 07-06-2016, 09:36 PM   #1
Murfdawg
Inner wheel bearing
I am replacing the front wheel bearings on my 64 c10 with standard drums. I got the
Timken bearings from Rockauto. The spindle is 1.375 and the inner bearing id is 1.372. It won't slide on the spindle. Is this normal? Is the bearing supposed to be a tight fit? My shop manuals don't indicate anything about this.
Help Please? Thanks!
P.S. I did search for this issue but found nothing.
Murfdawg is offline   Reply With Quote
Old 07-06-2016, 09:46 PM   #2
aerotruk63
Check The Champ, Demonstrator
aerotruk63's Avatar
Re: Inner wheel bearing
I can't help you much on the subject accept that the bearing should be a sliding fit.
You impressed the hell out of me when you said you have a shop manual.
Old 07-07-2016, 07:33 AM   #3
Murfdawg
You confirmed what I thought. A sliding fit. I guess I will try another set of bearings. Thanks!
Old 07-07-2016, 07:46 AM   #4
cg285
how did you get your measurements?
cg285 is offline   Reply With Quote
Old 07-07-2016, 08:21 AM   #5
aerotruk63
aerotruk63's Avatar
From the GM parts book:
62-66 GM Bearing inner part# 457052 TIMKEN LM48548 - LM 48510
62-66 Bearing Outer part# 457478 TIMKEN LM 11949 - LM11910
Old 07-07-2016, 08:40 AM   #6
cg285
if you look at the specs for lm48548 the id is 1.375 which would be correct for a zero fit. i would question how you got the 1.372
Old 07-07-2016, 11:56 AM   #7
jtrichard
What is the bearing number you have from R.A.?
jtrichard is offline   Reply With Quote
Old 07-07-2016, 01:05 PM   #8
Murfdawg
I measured the spindle and the bearing after I tried to mount the fully assembled hub. I removed the seal and measured the bearing and the spindle with a micrometer. The package the bearing came in was labeled Set 5, which is the correct bearing.
I also tried to slide just the bearing onto the spndel. No go.
Old 07-07-2016, 01:10 PM   #9
61K10
61K10's Avatar
I take it the old bearing came off easily? ck for any burs or nicks on the spindle. Maybe just a bad new bearing?
1961 chevy K10
my build is------------61K10 build
61K10 is offline   Reply With Quote
Old 07-07-2016, 01:48 PM   #10
cg285
i rebuild steering knuckles that take a zero fit for the bearing race. almost always the race has to be tapped in. after it is seating then usually it can be turned by hand.
what was your procedure for measuring the id? id's can be tricky
Old 07-07-2016, 04:25 PM   #11
Murfdawg
Well, this is a little embarrassing. After cleaning my glasses and using a magnifying glass and being very careful, I got 1.375 for the id. The bearing number is LM 48548. So the correct bearing.
I still could not get it on, until I polished the spindle extensively with emery cloth. Now I can get the bearing on sometimes. Sometimes it gets stuck. If I can get it past the taper on the spindle, it has plenty of clearance. I will have to be lucky to get the whole hub assembly on. I will try tomorrow.
Thanks everyone for your help.
