Need help identifying mirrors
I purchased these and I'm not sure they are what I thought....
Was hoping they are 69 below the eyeline mirrors. Please advise. Thanks, Rich
IT IS WHAT IT IS |
Re: Need help identifying mirrors
They are in awesome condition
IT IS WHAT IT IS |
I have all hardware and instructions
IT IS WHAT IT IS |
R/V mirrors I believe.
1982 K10 SWB 1987 V20 - Sold - Doh! |
I'm not sure if they were different in 69, but those look correct for a 72, mine has them listed on the SPID as:
- DG4 BELOW-EYELINE MIRROR And that is what they look like. I've seen a lot of aftermarket versions that are different in the way they attach the arm to the head (diff rivets too). Here is a shot of one mine. ---
--------------------------------------------------------- I'm not crazy, I'm chosen, there's a difference. ---------------------------- '72 K10 SWB, 350, sm465/np205 ---- ---- |
Where did you purchase them? I may be looking for set in the near future.
#7 | |
I need the longer arms on the bottom for 69-70. The search for mirrors will continue.......I'll list these for sale. Thanks man.
IT IS WHAT IT IS |
They will be listed for sale in the forum in a few minutes....I got them with a parts lot I purchased. Exc condition.
IT IS WHAT IT IS |
![]() Join Date: Aug 2014
I do not see them listed for sale yet, but I will take them pending price of course. Thanks, George
they are posted.....
IT IS WHAT IT IS |
![]() Join Date: May 2010
Your mirrors do not appear to be correct for 1972 either. The horizontal support the runs to the top edge of the door is not correct. Not sure about the legs, but they also appear a bit different. Measurements would help. There appears to be an additional "twist" at the door end in the support in the OP's picture. Here's a picture of an original 1972 DG4 mirror.
#12 | |
IT IS WHAT IT IS |
Here's a short tutorial with things I've learned regarding the 1969-1971 DG4 mirrors referred to on early SPIDs as "W/C MIRROR-JR-LH&RH" and on later SPIDs as "BELOW EYELONE MIRRO".
I've found that there were at least 2 variations. Both utilize the same hole pattern in the doors. The information below is based on my 1969 originals and a set now on my 69 that I got from a 1970 GMC. The most common, by far, appear to be the type I got from the 1970 GMC. Legs... The first version legs were like the originals on my early 69 (picture 1). They were quite straight at the bottom whereas the second version bowed out from the door (picture 2). My assumption is that the bow was added to provide additional clearance with the upper beltline molding which (assumption #2) was first offered sometime during the 1969 model year. Horizontal support to door... My first version supports (picture 3) measure 6-7/8 ". The second version (picture 4) measure 5-1/4". Mirror heads... The mounting brackets on my original mirror heads were offset vertically which allowed the owner to raise or lower the head by flipping the mirror. Most others I've seen are centered. I have no idea when that change occurred or if mine are truly unique. In an earlier thread I read, someone claimed that this was a Ford design head, but I'm 100% sure mine are original to the truck. See the next post for pictures of the assembled mirrors. |
Assembled mirror pics...
First... Original from my Dec., 1968, production 1969. Second... From 1970 GMC. Last edited by FirstOwner69; 07-07-2016 at 01:22 PM. |
#15 |
Here's a picture of a 1972 DG4 base showing dimensions.
#16 |
man where can I get a set of those.......I need them.
BTW my truck was built 10/68
IT IS WHAT IT IS |
#17 |
![]() Join Date: May 2014
Unfortunately that 'twist' is a bi#$% to try to straighten. I bought a set identical to those at a swap meet, thinking I could straighten than top mounting arm. I gave up
Bill 2004 Chevy Silverado Z71 Ext Cab 1500 1972 Chevy K-10 SOLD 1967 Chevelle SS |
#18 | |
Active Member
![]() Join Date: Mar 2018
Jeff
Previous C10's 69 SB CST - sold 72 Cheyenne Super LB - sold |
