Old 07-07-2016, 08:28 AM   #1
orange70c10
Red face Drip rail repair
Anybody repaired the drip rails on 67-72 trucks, my new project has some issues in this area that concerns me the most!
orange70c10 is offline   Reply With Quote
Old 07-07-2016, 10:29 AM   #2
LockDoc
The Older Generation
LockDoc's Avatar
Re: Drip rail repair
Pictures would be a help. It depends on where the rust is, how extensive, and whether it has traveled to the inside or not.... Be sure and check behind the visors inside. If you have bubbles in the paint there you will have rust also.
Replacement drip rails are available from the parts vendors.....
LockDoc
Leon
Old 07-07-2016, 10:44 AM   #3
67ChevyRedneck
67ChevyRedneck's Avatar
How bad are they?
Definitely check above the windshield. Push on the area above the windshield and pull the seal down to look for rust.
My truck just had minor damage around mine and it's good around the windshield so I recently sourced a set of clean originals as I've read the "look" of the aftermarket ones isn't correct. I literally just got them yesterday, so it will be a while before they come apart. Check the parts forum often for people offering cab cuts, that's how I got mine.
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 07-07-2016, 01:29 PM   #4
tdangle
tdangle's Avatar
I had to replace the one at the drivers side. Dad had put a guttermount CB antenna there which caused a rust problem. I bought a replacement and don't remember it being much of a problem. Doesn't really line up as good as the original but looks OK. One thing I do remember is not seeing the center drip rail repo. Just the 2 sides. Good Luck.
Terry
1970 Custom Camper/C20 , GM Crate 350/7004R, Dana 60, factory AC
tdangle is offline   Reply With Quote
Old 07-07-2016, 01:35 PM   #5
orange70c10
Thumbs up Re: Drip rail repair
Thank you guys, I'll check those areas yall mentioned. Majority of the rust is on the face of driprail. I hope. Thanks for your help!
Old 07-07-2016, 04:38 PM   #6
Gromit
Your post reminded me of something I saw on member Bruce88's build thread that might be of help to you and others:
Bruce88 used "Fill Welding" to repair rust around the windshield and drip rail areas.
I had seen this for filling holes such as trim holes but never to build up a thin area - I think what he did came out very well and probably easier than cutting out and replacement. Though the welding skills required look daunting to me anyway.
I'll attach one of his photos (I'm not sure about the protocol or whether posting someone else's photo is considered bad manners if it is on the same site) - but he has lots more photos on page 4 of his build thread; here is a link:
http://67-72chevytrucks.com/vboard/s...=318544&page=4
Update: I thought I was posting only one photo but three of them came over with the cut-and-paste
Gromit is offline   Reply With Quote
Old 07-07-2016, 05:51 PM   #7
67ChevyRedneck
I did something similar when I pulled the back window in my truck. Found a bunch of small pin holes. Instead of cutting them all out with a big patch I drilled them out larger and filled them in. You'll quickly find out if the area is larger on the backside, the welder will either burn right through the metal or start to fill in.
These are a couple spots where there was holes:
Jesse James
Project "On a Dime"
Old 07-07-2016, 07:20 PM   #8
orange70c10
That helps a bunch, thank you! I'll yank the glass out and see what I'm dealing with.
