Old 07-09-2016, 11:04 PM   #1
Mrturner1
I finally did it!!!!!
Some of you guys may know about my truck and a lot of guys probably have no idea what I'm talking about but I gotta share this.
I've been working on my '70 c10 for probably 6 months straight, it started with just wanting to identify the cam that was clearly in it by the lope of the idle. I posted a thread and a bunch of guys jumped in and walked me through pulling the whole motor out, putting it on a stand and stripping it down to just the block and crank/rods/pistons. Up to that point I had never done more than maybe a water pump and some brakes, a clutch here and there, and a timing chain once on a 5.0 stang.
Short story long, I found a Lunati cam and some nice camel hump corvette heads, but decided to change everything for the experience and because I just can't leave well enough alone I rebuilt the top end with RHS 170cc heads that have new comp valve springs, comp pushrods, and comp roller tip rocker arms, a Comp 280H cam .480" lift and 230 duration @ .050" installed straight up, an Edelbrock Performer RPM manifold, Holley 750 double pump, long tube headers and Flowmasters. The rear end was stock and terrible, now it's a 3.73 mini spool which is loads of fun. Trans is a th400 that can with it, but now has a B&M Holeshot 3000 rpm stall and an auxiliary cooler plumed into the system along with the built in one the radiator has. Flexalite dual electric fans replaced clutch and 5 blade clutch fan. MSD Pro Billet replaced the GM HEI that I locked out with JB Weld trying to make the truck run good like a dummy. I also put a bunch of Autometer gauges in it and a B&M truck ratchet shifter so the interior looks kinda cool.
I fought with this thing for 6 long months, tried 3 different carbs, 3 different distributors, and every timing curve you could imagine with every spring weight and bushing available on the market. I tore it down to the block twice changing head gaskets trying to dial in quench and get more compression and power, and thought I blew a head gasket once lol. I also re-adjusted the valve lash about 9 times in 2 weeks trying every method out there, and even thought I flattened a cam lobe once and tore it down AGAIN only to find out that the throttle cable pulled a spark plug wire off the distributor....I know, wow.
Today I put in a new harmonic dampener that had degree marks all around it because none of the 3 dial back timing lights I got read right. I also put on a Weiand high flow water pump that seems to have taken care of my creeping idle temp. I adjusted the air/fuel on my carb and found out it wasn't the 3 different power valves or 6 sets of jets I tried, it was just air/fuel mixture....again, wow. Timing with this new balancer is really a lot of fun because I can watch the curve and dial it in perfect, which has finally happened. So it's not overheating, my timing curve is perfect, carb is dialed and all is well, so obviously I have to drive it. I took it out for 2 hours, which is amazing because I couldn't go 15 minutes without a serious issue before turning me back home. It doesn't ping or detonate, it shifts perfect manually or in Drive, stays below 195* no matter how I drive it, and it FINALLY breaks the tires loose from a 20 mph roll! I've been waiting for that moment for a looooong time! After I got the hot rodding out of my system I got to do something in this truck I haven't done for a year at least, and that's just hang an arm on the window ledge and cruise for a good hour with the windows down. It was all worth it when I was able to do that breaking the tires loose from a roll is awesome, but after these past 6 months I really just wanted to be able to trust the truck to not break down or overheat or have some other problem.
It's my first build, and I bet a 100 bucks to Grumpy Old Mans 12 pack of Heineken it's got 400hp I'll post a pic of the motor before and after so you guys can see the difference.
Mrturner1 is offline   Reply With Quote
Old 07-09-2016, 11:16 PM   #2
firedemon
Re: I finally did it!!!!!
I have always had problems with holly carb air fuel screws staying put check them every time you think somethings off
firedemon is offline   Reply With Quote
Old 07-09-2016, 11:20 PM   #3
Grumpy old man
Grumpy old man's Avatar
Good for you ....Now did I hear someone mentioned Heineken ? ? I wish you were closer we could see how it does next to a dinky ol 292 short bed with a few old extra parts bolted to it ?
Old 07-09-2016, 11:32 PM   #4
Grumpy old man
Now that you got it to GO , it's time to fix the whoa ! Upgrade the brakes and suspension ,sway bar to handle your new found power ! I know it never ends !
Old 07-09-2016, 11:32 PM   #5
snj8198
snj8198's Avatar
hahahahaha! Congrats Matt!
Grumpy: better cash in before Matt burns up all the beer money.
Steve
1971 GMC Longbox. Full Roller Stroker 489 w/ FiTech EFI, Chris Straub Cam/NV4500/205/D60/14B w. Grizzly Locker and 4.11's. 2" Lift on 33's
snj8198 is offline   Reply With Quote
Old 07-10-2016, 12:28 AM   #6
Mrturner1
I was thinking the same thing. When I finally came home I shut it down and had this huge relief that now I could finally start doing the brakes and suspension! And I'm definetly ready, I thought it would never end. I even started making a plan last week to get a GM crate and put my cam/intake/carb on it.
I don't know, I think she could take that 292 short bed haha the stall converter changed everything regarding performance, definetly a crucial part of the combo
Old 07-10-2016, 12:29 AM   #7
Mrturner1
That's hilarious lol and true. Thanks man I'm glad it's done for now
Old 07-10-2016, 12:31 AM   #8
Mrturner1
This is the first tear down that started as a cam identification lol
Old 07-10-2016, 12:32 AM   #9
Mrturner1
This is what it looked like when I bought it
Old 07-10-2016, 12:35 AM   #10
Mrturner1
Engine bay a mess, and a rats nest for wiring
Old 07-10-2016, 12:36 AM   #11
Mrturner1
All painted up and assembled!
Old 07-10-2016, 12:38 AM   #12
Mrturner1
Engine bay painted and motor back in
Old 07-10-2016, 12:40 AM   #13
Mrturner1
Mini spool almost in, needed some convincing from a big mallet and half a 2x4 lol
Old 07-10-2016, 12:42 AM   #14
Mrturner1
Out with the Edelbrock and in with the Holley!
Old 07-10-2016, 12:43 AM   #15
Grumpy old man
With all that under hood time is there any paint left on top of the fenders or are you working on your patina paint job ?
Old 07-10-2016, 12:44 AM   #16
Mrturner1
New Powermaster to run the Flexalite fans I put in
Old 07-10-2016, 12:45 AM   #17
Mrturner1
Carb installed
Old 07-10-2016, 12:47 AM   #18
Mrturner1
And this is from today, finally done and dialed in, and lookin purdy too!
Old 07-10-2016, 12:47 AM   #19
Mrturner1
Sorry for the sideways pics, I hate that
Old 07-10-2016, 12:48 AM   #20
Mrturner1
The sides are covered in grease and trans fluid lol it's still primered grey though just like it was when I bought it. Still deciding on a color for it
Old 07-10-2016, 12:50 AM   #21
Mrturner1
Still primered, but pretty darn cool lookin
Old 07-10-2016, 11:32 AM   #22
Mrturner1
I'll definetly be checking a/f screws and spark plug wires if anything screwy starts happening lol
Old 07-10-2016, 11:43 AM   #23
Grumpy old man
How much have you learned thru this adventure ? It's a whole different feeling when you turn your own wrenches and build it yourself , anyone can write a check not everyone can rebuild an engine and have it run great when their done . You've done well even if there were times some of us wanted to ... let's just say encourage your forward motion using a lower appendage at speed !😁
Old 07-10-2016, 12:07 PM   #24
Money_pit
Money_pit's Avatar
Congrats on job well done.looks good
71 C10 Finally took a leap and did the 5.3 4l80e swap.
Running the Holley Terminator Xmax. Still working bugs out.
Money_pit is offline   Reply With Quote
Old 07-10-2016, 10:15 PM   #25
sleepertruck72
sleepertruck72's Avatar
Nice rig !!! Glad to hear you didn't give up
72 C20 Longbed
05 1500 Z71
sleepertruck72 is offline   Reply With Quote
