Old 07-11-2016, 07:33 AM   #476
dug224
dug224's Avatar
Re: Rods 57
Nice job on the seat belt mounting point up high. Love the straight sheet metal! dug
dug224 is offline   Reply With Quote
Old 07-11-2016, 10:14 AM   #477
Kim57
Kim57's Avatar
Re: Rods 57
Looking good.
Kim
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=283107
Kim57 is offline   Reply With Quote
Old 07-12-2016, 02:12 PM   #478
Rods57
Rods57's Avatar
Re: Rods 57
Originally Posted by Kim57 View Post
Looking good.
Kim
Thanks guys, the belts really don't fit well anywhere else, i modified the brackets to turn them 90 degrees so they faced forward on the floor. Hope to start jamming out the cab and fenders and put it all back together soon.
Rods57 is offline   Reply With Quote
Old 07-12-2016, 02:18 PM   #479
Rods57
Rods57's Avatar
Re: Rods 57
did one small thing, put my newly painted hood hinges and new spring together. Now i can start growing the pile of red parts...
Old 07-13-2016, 12:13 PM   #480
Rods57
Rods57's Avatar
Re: Rods 57
Anyone have an opinion on the rear cross sill. Originally it was tacked to the bed sides, i am sure for stability. so the question is do you tack it again or just bolt it? whats your thoughts?
Old 07-14-2016, 03:19 PM   #481
II_Slow
II_Slow's Avatar
Re: Rods 57
Very good question - subscribing for ideas here. I have mine bolted but there are some areas on both ends that you either have leave it unbolted, or leave some bolt heads exposed (unless you reach WAY up into the stake pockets). Mine seems like it is going to rattle to much without securing it somehow. My whole bed frame is welded together and it wouldn't be practical to weld the frame to the bed sides.
1955 SB Stepside 3100 big window cab on a 99 Ram 2500 Frame w/ 12-V Cummins diesel power and
47RH AOD transmission
http://67-72chevytrucks.com/vboard/s...d.php?t=640042
II_Slow is offline   Reply With Quote
Old 07-31-2016, 08:51 PM   #482
Rods57
Rods57's Avatar
Thumbs up Re: Rods 57
Not much to show except dust....sand sand sand.
I hate sanding, but love love love Filler primer.....
Old 08-01-2016, 05:45 PM   #483
_Ogre
_Ogre's Avatar
Re: Rods 57
change hands often when sanding to avoid getting popeye arm on one side
shop air compressor timer
Old 10-20-2016, 02:40 PM   #484
Rods57
Rods57's Avatar
Re: Rods 57
small update. I epoxy primed and blocked the fender that i made out of two her is the before and after shots. A little more primer and blocking and were good...
Old 10-20-2016, 03:06 PM   #485
dsraven
Re: Rods 57
just going back a page or 2 to where you were having contamination issues with the air. I have installed an electric auto drain on my tank which is wired to the shop lights. that way it only drains when the lights are on-when you are in the shop basically. this really helped with moisture when using the sandblasting cabinet. the drain is adjustable for length of drain and frequency of drain cycle. it does sorta scare the sh@%t outta guys that don't know it is there. especially if they happen to be standing next to the tank, haha.
I have had issues in the past with contaminants while painting and came to the conclusion that my air lines and hoses were to blame. I use my shop for mechanical repairs mostly, with some bodywork blitzes from time to time, and I was using my regular air hoses and regulators etc when painting. bad idea. the shop hoses had contaminants in the hoses that came out when spraying. I have dedicated paint hoses and regs/filters etc to use for painting now. no more issues. I ran some cleaner through the shop hoses and was quite surprised to find what came out.
another thing I have seen on these forums is guys that use newspaper for masking. it works but is covered in fine "dust", for lack of a better word, that gets blown off onto the fresh painted surface as you are spraying. that masking paper may seen expensive until you gotta clean up a mess on the otherwise great looking paint job.
ok, end of rant.
your truck stuff looks great, by the way. good luck with the back. take it easy man.
Old 10-21-2016, 07:57 AM   #486
Kim57
Kim57's Avatar
Re: Rods 57
Fender is looking real nice.
Kim
My build thread
Old 10-21-2016, 09:27 AM   #487
dsraven
Re: Rods 57
On your paint booth ideas, one thing i have done in the past is to make up a 2x4 frame the same height as a furnace filter and as wide as the garage door. Then staple a row of filters to the frame, place the frame in the open garage door opening and let the door down on it. You will have cross flow ventilation that way. For respirator air keep an eye out for a cpapp machine. Some guys know them as a snore machine. You wear them at night to help with sleep apnea. Anyway, they are just a supply of fresh ambient air through a small fan in a machine out to a face piece. You could place the machine out in some fresh air and just run a long hose to your face piece inside the booth. Better than just a filter mask. Run the hose together with your paint gun air hose, taped every so often, so you only have to deal with one rats nest. Paint fumes kill.
Nice looking shop. I like what youre doing with the truck too. Looks good. Love the color. Like you dipped it in plastic. Good job on the paint, smooth. Have you painted lots before? Nice to see real paint, not just flat black or fake patina, cant wait for that trend to finish. Back in the day there were lots of primered hotrods driving around but that was because guys couldnt afford to paint. Nowadays guys paint stuff and then buff the nice new paint down so it looks "old" again. Dont seem right to me, Just a personal opinion though.
Hey, keep up the good work and please keep posting pics for us guys who are laid up and cant work on our own stuff.
Old 10-21-2016, 02:52 PM   #488
Rods57
Rods57's Avatar
Re: Rods 57
Kim
Thanks Kim
Thanks, Lots of good suggestions. I got a hold of a company that sells paint booth filters to body shops and am building a frame to insert them into. I will post some paint test panels with the filters in place to see if the contaminants go down.
Old 10-21-2016, 08:18 PM   #489
Rods57
Rods57's Avatar
Re: Rods 57
To late, i got Popeye arm for sure. and i have sanded through the skin on my finger many times....
Old 01-09-2017, 01:55 PM   #490
Rods57
Rods57's Avatar
Re: Rods 57
Final primer on a few items. Slowly growing the "done" pile..
Old 03-14-2017, 12:28 AM   #491
Rods57
Rods57's Avatar
Re: Rods 57
Small update but a big step. got the cab all blocked out in 400 grit, looking good almost ready to put some color on it....
Old 03-14-2017, 06:47 AM   #492
ChuckDriver
A320 Pilot/USAF Retired
ChuckDriver's Avatar
Thumbs down Re: Rods 57
Awesome!
ChuckDriver is offline   Reply With Quote
Old 03-14-2017, 07:58 AM   #493
Kim57
Kim57's Avatar
Re: Rods 57
Very nice.
Kim
My build thread
Old 03-14-2017, 11:37 PM   #494
Rods57
Rods57's Avatar
Re: Rods 57
Thanks for the comments, I have painted a few things, no pro though just stubborn and lucky i guess, and i have friends that are good and tell me how to do it.....
Originally Posted by ChuckDriver View Post
Awesome!
thanks, getting excited now
Very nice.
thanks Kim,
Kim
Old 03-15-2017, 12:13 AM   #495
dsraven
Re: Rods 57
I notice that you have the firewall poly'd off. just a heads up for when the colour goes on, make sure to seal it off from the bottom side as well or the overspray will find it's way onto the underside of the poly, like onto the firewall if it is finish coated.
doesn't it feel good to be almost ready for paint? been there, not on this project though.
Old 03-15-2017, 12:19 AM   #496
Rods57
Rods57's Avatar
Re: Rods 57
Thanks, i do that. I just cover it when i sand because i know i will slip up once or twice and want to protect it as much as possible. its crazy wher eoverspray gets, like every where....
Old 03-15-2017, 12:39 AM   #497
dsraven
Re: Rods 57
ya, they should call it underspray, haha. it gets under everything.
your project is really looking good. keep posting pics, it helps the rest of us get off the couch.
Old 06-13-2017, 11:27 AM   #498
Rods57
Rods57's Avatar
Re: Rods 57
Grettings from the sanding shop......at least thats what it feels like. I did something else this weekend to get my head back on track and was able to get the motor and trans back in the truck for hopefully the last time, with No scratches on the firewall..... Made a design change too, differnt valve covers.
Old 06-13-2017, 12:21 PM   #499
Kim57
Kim57's Avatar
Re: Rods 57
That looks real nice.
Kim
My build thread
Old 06-13-2017, 12:57 PM   #500
ChuckDriver
Re: Rods 57
Looking good Rod!!
