Old 03-15-2004, 02:48 AM   #1
Bluegoose972
Pictures of Rocker Box Mounting???
Does anyone have a picture and details on the mounting of their rocker boxes? Mine were welded in position so I'm a little unclear on how they are SUPPOSE to mount. I'm guessing that the slotted holes are for bolt alignment along the main body support. Is the rocker box suppose to attach to the outside body panel rocker section? Mine were actually welded on both sides. And correct me if I'm messed up here, but are they suppose to be welded in place? What a pain to remove if that is the case.
Bluegoose972 is offline   Reply With Quote
Old 03-15-2004, 03:00 AM   #2
skid
I'm sure they were welded at the factory.
Toys:
72 K5 Blazer
74 Vette
skid is offline   Reply With Quote
Old 03-15-2004, 08:49 AM   #3
vtblazer
vtblazer's Avatar
Yep, Welded
Get out the grinder
vtblazer is offline   Reply With Quote
Old 03-15-2004, 11:23 AM   #4
Gee_Emm
The welds go it the holes and notches. And yes they are a pain to remove. There are a few bolts that hold them on but every where else including the front lip is welded.
Gee_Emm is offline   Reply With Quote
Old 03-15-2004, 04:59 PM   #5
mister.freeze
mister.freeze's Avatar
I unbolted the ends, and will use a plasma cutter to get the rest of it out. I'll be fabrcating gas tanks to full that void. How structural are the rocker boxes? Why are they there? I want to be able to remove these tanks once they are made.
'72 K5, known as 'the Fox.'
mister.freeze is offline   Reply With Quote
Old 03-15-2004, 05:02 PM   #6
bpmcgee
bpmcgee's Avatar
Mr. Freeze,
The rocker boxes are THE structural element there. Without them your doors won't line up anymore.
They are there to make up the rigidity lost when you cut the top and back out of a pickup cab!
Brian
bpmcgee is offline   Reply With Quote
Old 03-15-2004, 05:06 PM   #7
mister.freeze
Good to know!! I'll be sure to make them plenty srong and have them mount appropriately. Without them, will the body sag between the front and rear body mounts? Would it be a good idea ti supplement these? I'd really like a lot of input before I get started.
Old 03-15-2004, 06:37 PM   #8
Bluegoose972
Well, I should have guessed. I didn't see any bolt holes but figured that surely the PO had taken a short cut. I guess that explains some of the holes he had cut in the bottom of the rocker pans for access.
Yes, a major pan in the butt! My wife thinks I'm nuts but the more I fight with this truck, the more I love it!!!!
Old 03-15-2004, 06:38 PM   #9
2wdBlazer
The Blazer King
2wdBlazer's Avatar
Make sure the top is on when putting it all back together. It will put everything in alignment.
72 2wd Blazer. Its the superbichinest, megacoolinest, superflowinest.
2wdBlazer is offline   Reply With Quote
Old 03-15-2004, 07:13 PM   #10
Bluegoose972
I no longer have a top. I gave it away a few months ago to a board member. Going full convertible.
Old 03-16-2004, 02:04 AM   #11
bpmcgee
bpmcgee's Avatar
Blue,
Do you have the factory assembly manual? If you do, it has a grid that you can use to get the right measurements for alignment.
Brian
Old 03-16-2004, 05:00 PM   #12
Bluegoose972
I'll look for that tonight. I spent about a half hour going through the book, but it's very easy to miss a piece of information. Boy, an index would be really helpful!
Old 03-18-2004, 10:31 PM   #13
red71cheyenne
Back in the sticks
red71cheyenne's Avatar
I found the easiest way to get them off was to break out the Boz'all! A nice new blade helped a lot too. Had to do some wedging to get the blade in between all the welds. You also have to grind out the welds at the front where it mounts to the floor board seam. After that, it should drop off. If you find your assembly manual, could you give me the door opening measurements? I'm reassembling without the top on at this point. Thanks, Jeff.
1971 Cheyenne C-10 w/700R4 and Tuned Port Injection
1969 K5 Blazer w/Tuned Port
2010 2SS/RS Flaming Orange Camaro
2011 K1500 Suburban
2014 K1500 Pickup
2008 Nissan Altima? The wifes' hoopty
red71cheyenne is offline   Reply With Quote
Old 03-25-2004, 02:42 AM   #14
kiley
body sag
When I take my hard top off in the summer my drivers side door doesn't close very well. It's even popped open when the body flexes enough.
kiley is offline   Reply With Quote
Old 03-30-2004, 03:41 PM   #15
red71cheyenne
Back in the sticks
I got my new assembly manual in the mail yesterday(Thanks ****************!!) and it says that you use shims in the cab mounts for position 2 and 3 to set the door opening alignment. You might try either replacing or shimming your cab mounts to help with that door closing issue. Jeff.
2011 K1500 Suburban
2014 K1500 Pickup
Old 04-10-2004, 11:07 AM   #16
earnhardt221
New Rocker Boxes
Hey, Have you Guys seen the new LMC catalog.They have new rocker boxes. If you didn't have them just thought you may wanna know.
Tom
earnhardt221 is offline   Reply With Quote
Old 04-10-2004, 11:27 AM   #17
Gee_Emm
Wes at Classicheartbeat.com has had them for a couple months now.
Old 04-10-2004, 06:51 PM   #18
Classic Heartbeat
Project Junkie! Fishing Poor!!
Classic Heartbeat's Avatar
Thank you Gee_Emm. We were the ones that had them developed also. LMC does nothing to help develope new parts for these trucks. We just don't have the kind of money to get the exclusive on the parts, so anyone can purchase them for resale. WES www.ClassicHeartbeat.com
On-line catolog
Classic Heartbeat Pickup Parts
WEHEPP@comcast.net
Call us Toll Free (888) 338-2502
Like Us on Facebook
No appointment necessary.
72 BB Chevy Custom Deluxe / Custom Camper
67 I-6 (Soon to be 5.7 LS1) Panel
68 BB Chevy Short Bed
72 6.0 LQ9 Short Bed Chevy 4X4
Olympia's fastest growing truck parts supplier.
Olympia's home for Wayward Chevys
Classic Heartbeat is offline   Reply With Quote
Old 04-10-2004, 11:10 PM   #19
earnhardt221
i think i'm going to start buying my parts from Classicheartbeat. Sorry Wes i didnt know you guys develop new parts.I'll be getting one of your catalogs.Thanks for the info
