07-14-2016, 10:05 AM | #1 |
Air vent on driver side?
My '84 does not have an air vent on the driver side by my left foot. Matter of fact there is nothing there at all. There is an open hole which looks like its for a manual vent like on the passenger side but I'm not quite sure if the driver side should have a vent at all. Can anyone confirm? LMC does not list a vent for the divers side. What belongs there?
'84 K10, SM465, NP208, 3.42 Gears, 33x12.5-15 GM 4 bolt 880 roller block, 062 Vortec Heads Comp Cams XR258HR-10, MSD Street Fighter HEI Edelbrock: Performer Intake 2116, 1405 Carb Long tube headers, 2.5" duals to Flow Master Super 40's Vortec Engine Build |
07-14-2016, 01:56 PM | #2 |
Re: Air vent on driver side?
There is no vent on the left floor area
07-14-2016, 02:00 PM | #3 |
Should there be a panel there? Pics?
07-14-2016, 02:28 PM | #4 |
I found an old photo of when i was in the process of changing from maroon to grey. The panel I believe you are referring to is down under the dash, right there by the parking brake pedal.
From LMC, it's part #1 of the Air Vent Components. As you can see, the right side is made for a vent, but the left side is not. http://www.lmctruck.com/icatalog/cc/full.aspx?Page=94 |
07-14-2016, 03:06 PM | #5 | |
Thanks!
07-14-2016, 04:50 PM | #6 |
On earlier year trucks, there was an opening if it was a non-A/C vehicle. WE had an old 78 that had the hole. But for some reason, GM decided to do away with it in the later years.
I'm kinda bummed because my cab has a little rust spot. It's inside the cowl cavity near the seem by the E-brake pedal. The E-brake side looks deceivingly good and you can only see the spot if I use a scope. (which I did to make sure all was ok up there.) This whole thing would have been much easier to see and treat if GM left the hole there, dang it! Since there is no way to get my hand in there from the top or the bottom, my plan is to pour a small can of POR15 down from the top and hope is covers the small rust spot.
Jay Gesner Atlanta, GA 1985 C10 Long Bed 4X2 LS 5.3, 4L60E Father/Daughter Project |
07-14-2016, 10:38 PM | #7 |
That's very strange, my 86 has no A/C but I do have the driver vent
07-14-2016, 10:41 PM | #8 |
Think you could post me a pic?
07-14-2016, 10:44 PM | #9 |
Once I get the truck back from the upholstery shop I will. I was just thinking about walking outside and snapping it but reliable I don't have my truck. ;( any day I'll have it back
07-14-2016, 11:29 PM | #10 |
Non ac trucks have the air vents, ac trucks use the passenger side vent to draw air from and there is no vent hole on driver side
1981 K-5 Blazer 2wd 1985 C-10 Short step 1988 C-10 Suburban |
07-15-2016, 10:12 PM | #11 |
So I took a look and found that I have a panel there but I can see it's not the correct one. There's some left over gasket around the hole where the vent should be.
07-21-2016, 07:23 PM | #12 |
Just picked up the truck from the upholstery shop, here's the panel from my 86 step side non-Ac.
07-21-2016, 07:25 PM | #13 |
I can't figure out with my cellphone posting photos, multiple at the same time.
07-21-2016, 08:22 PM | #14 |
Awesome, thanks man. Now I just need to find one. Lmc doesn't seem to have one.
07-21-2016, 10:30 PM | #15 |
Brothers sells it. Part number PKP87NL 73-91 kick panel, full cover, left without A/C $34.99
07-21-2016, 10:51 PM | #16 |
Thanks! Their site isn't very user friendly on mobile... I'll finds it though.
07-21-2016, 10:53 PM | #17 |
Just got there catalog in the mail today! And agreed about there website. I do believe I've seen same panel from LMC too
07-21-2016, 11:23 PM | #18 | |
https://www.brotherstrucks.com/mobil.../products/549/ They still don't look like the one you pictured though...
07-23-2016, 01:12 PM | #19 |
my 88 crew has a drivers vent. no factory ac originally.
88 military v30 crewcab shortbed 5.9 cummins, nv4500, 205 86 k30, 89 diesel burb, 76 gmc pathfinder 71 longbed 5.3 4l80 http://67-72chevytrucks.com/vboard/s...d.php?t=522535 |
