Old 07-15-2016, 01:49 AM   #1
Tony's 68
68 Chevy C-10 Turn Signal Question
Is this truck normally so fricken sensitive with the turnsignal cancellor? If I barely move wheel the opposite direction of turn it cancels all to easy. Is this normal or can I adjust the cam or sensitivity?
Tony's 68 is offline   Reply With Quote
Old 07-15-2016, 06:14 AM   #2
Grumpy old man
Grumpy old man's Avatar
Re: 68 Chevy C-10 Turn Signal Question
48 year old technology, Has it been replaced with an aftermarket part ?
Old 07-15-2016, 07:08 AM   #3
68C15
blood type; Retumbo
68C15's Avatar
the switch is worn out, time for a new one
Man rule #77...if you own a 67 stepside with a caddy 472 you will never be in danger of loosing you man card
68C15 is offline   Reply With Quote
Old 07-15-2016, 07:11 AM   #4
Do you have a lot of play in the steering? The canceller is designed to turn the signal off once you turn steering wheel back in opposite direction. C/10-C/30 are all the same, and so are K/5-K/20
Old 07-15-2016, 10:55 AM   #5
Tony's 68
Question Re: 68 Chevy C-10 Turn Signal Question
Will aftermarket switch/cam help? Other dudes reply was that 48 yr. old technology is limited. Just really want to know if it can be modified to not turn off so damn easy when when barely moving the steering wheel in opposite direction?
