Old 07-11-2016, 09:57 PM   #1
Lugnutz65
Lugnutz65's Avatar
Disc brake conversion pics and questions
Yes, I did review the relevant FAQ section about disc brake swaps but didn't find my answer.
So thanks in advance for the help.
I have 3 questions.
1. Do I run the 3/16" line from the MC and prop valve to the front discs?
2. Do I run the 1/4" line to the rear axle flex hose?
3. Do I keep the rear axle 3/16" hard lines that come off the rear axle distribution block?
The back story:
I'm installing a CPP front disc brake kit in my 1965 C10. The CPP tech help line was not helpful.
The CPP supplied front brake hoses that came with the kit have fittings for a 3/16" line. I will be using a 1995 Chevy Blazer Booster and MC.
My current 1965 front drum brake lines are originally 1/4". Then the 1/4" line runs back to the splitting block at the back axle. The hard lines to the rear drums are 3/16". That's the original stock setup.
My 65 C10 build: www.lugnutz65chevystepside.weebly.com
Want to know more about T5 transmissions? My website has a T5 Info Page and a Step by Step T5 rebuild.
Lugnutz65 is offline   Reply With Quote
Old 07-12-2016, 12:24 AM   #2
slepysal
slepysal's Avatar
Re: Disc brake conversion pics and questions
When I did my swap I had already installed a dual circuit drum master and split the lines.
I installed the disc /drum master and prop valve I used the same rear hard line but had to switch the front one to 3/16
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes.
"Over, Around or through it... "
slepysal is offline   Reply With Quote
Old 07-12-2016, 09:06 AM   #3
Lugnutz65
Lugnutz65's Avatar
That's great news. My memory was telling me something different so I'm glad to hear that the 3/16" line for the front is correct. The rear lines are essentially 3/16" as well since the rear lines at the axle are 3/16". That still has me scratching my head. I see no need to change the rear hard lines. I guess the proportioning block takes care of the whole issue. Maybe someone will comment.
Old 07-13-2016, 08:02 PM   #4
canadian_diesel1964
hey Lugnutz..hows it going...I have a 96 Booster MC in mine from a blazer...i ran 1/4 from the Prop Valve(front circuit on valve) to the rear circuit split to 3/16 and 3/16 from the prop valve(rear circuit on valve)to the front that are split to 3/16...its all apart now but its set up that way to go back in..I welded an adjuster rod for the pedal set up...hope that helps..BTW my T5 is going in tomorrow ...do you know the size of the spacers you used to lower the E brake set up?..Thanx
canadian_diesel1964 is offline   Reply With Quote
Old 07-15-2016, 10:54 PM   #5
Lugnutz65
Lugnutz65's Avatar
Sorry for the delayed response. I deleted my 1965 e-brake crossmember setup. I am using a modified version of the 1966 & up e-brake.
But to answer your question, just measure the gap between the crossmember flange and the top section. Just match that distance. The photo is one I saved from someone else's post. I hope this helps.
