Old 07-17-2016, 10:50 PM   #1
II_Slow
II_Slow's Avatar
Alternative hood brace for 2nd gen 55
I finally tried fitting the hood on my 55 pick-up (2nd gen). The brace hits the intercooler duct and looks like it will hit the radiator if I could close it any further. Is there anything out there already available, or can someone please share their solution. Did I mention it's Cummins powered?
1955 SB Stepside 3100 big window cab on a 99 Ram 2500 Frame w/ 12-V Cummins diesel power and
47RH AOD transmission
http://67-72chevytrucks.com/vboard/s...d.php?t=640042
II_Slow is offline   Reply With Quote
Old 07-17-2016, 11:33 PM   #2
Speedbumpauto
Speedbumpauto's Avatar
Re: Alternative hood brace for 2nd gen 55
Maybe?
Speedbumpauto is offline   Reply With Quote
Old 07-18-2016, 08:44 AM   #3
bowt1ed
Another idea to stop the notorious oil canning of 55/56 hoods. I bought a 57 sedan brace from Danchuk and modified to fit. With the addition of a nutsert, bolts off/on for adding sponge pad.
Cheers, Jim
bowt1ed is offline   Reply With Quote
Old 07-18-2016, 02:50 PM   #4
dwcsr
Hollister Road Co.
dwcsr's Avatar
Look for a 6 cylinder hood cross brace, the cross brace was offset to the passenger side to clear the carb filter housing.
Old 07-18-2016, 02:53 PM   #5
OrrieG
OrrieG's Avatar
What ever you come up with leave some way for adjustment. The stock cross brace is not a true X, the sections are bent to give the guys on the assembly line a way to adjust the hood diagonally.
Old 07-18-2016, 03:42 PM   #6
II_Slow
II_Slow's Avatar
Seems like the one I have is off-set to the passenget side already, but not near enough. I have two (rusty) hoods, so I'll check them all. The hood brace for the front hinged hood kit might be as option as well. I'm sure I'll figure something out - pretty much every part has been massaged one way or the other on this thing. Maybe some small tubing and rod ends - that would be adjustable.
Old 07-21-2016, 12:54 PM   #7
II_Slow
II_Slow's Avatar
Upon further review - every brace I have (all three of them) have the intersection near the center. Guess I don't have a six-cylinder (offset) brace to try.
