Old 07-18-2016, 10:25 AM   #76
C10_ustacould
A day late and $1 short...
C10_ustacould's Avatar
Re: New Daily Driver
Originally Posted by Hart_Rod View Post
Is the 73-87 slider the same? I have one that I got from Zack. LMK.
According to Classic industries they are different, thanks anyway!
Buck
Instagram: C10_ustacould
1963 SWB Fleet Side 528 Desert Beige
Milly
1967 SWB Step Side 506 Medium Blue
The Old Girl
1968 SWB Fleet Side 503 Light Green
Ellie SOLD
1965 SWB Fleet Side 507 Light Blue
Prescription Strength SOLD
1971 SWB Fleet Side 521 White
Shiro SOLD
1968 SWB Step Side 503 Light Green
My Old Farm Truck SOLD
C10_ustacould is offline   Reply With Quote
Old 07-18-2016, 07:03 PM   #77
knomadd
knomadd's Avatar
Originally Posted by C10_ustacould View Post
Were the brake lines you bought a direct fit to the master cylinder, or did you have to bend your own? Which vendor did you use?
I bought the whole truck kit from Right Stuff Detailing. However, since I'm using a hydroboost system with a wilwood master and adjustable proportioning valve, I used the wilwood lines from the master to the prop valve. I also straightened and re-bent the pre-bent stuff from the prop valve down to the frame. Either way, I did not cut and reflare any of it.
-Duane
C/10 Club Texas member
1971 Chevy C10 "Brutus" SWB Fleetside 2016 6.0L (L96) 6L90E (driver/project)
1965 Pontiac GTO "Royal Goat" 400/TH400 w/AC (my baby)
knomadd is offline   Reply With Quote
Old 07-18-2016, 08:26 PM   #78
C10_ustacould
Good info, thanks!
Buck
Milly
The Old Girl
Ellie SOLD
Shiro SOLD
Old 07-23-2016, 05:36 PM   #79
C10_ustacould
The two barrel carb on this old beater just wasn't cuttin' it. I've been collecting parts for the last month or so to swap in a 4 barrel. I just finished up the swap and took it for a ride, what a difference! I thought I might be using too much carb for the little 307 but the 600cfm Edelbrock seems to work just fine. I searched for a used 500cfm unit but they are pretty scarce. I didn't paint anything, I really wish I had an old air cleaner, the chrome one sticks out like a sore thumb, but I had to have one so it'll have to do. Maybe I'll paint it flat black...
Not really a big deal but here are a few pics.
Last time it will look like this... stock.
Oh the madness has begun!
Starting to come together. only fifteen more trips to the parts store!
Just few things to button up, plug wires, vacuum plugs, and build a new throttle arm.
All done, the damn thermostat housing and oil fill tube stick out like a sore thumb. I'd buy more shiny stuff but I'm not sure if we're going to stay with a gen I small block. And we do, I'd rather it look more stock-ish like STP67-72s Lola does under the hood.
Anyway, with just a couple miles on the new induction set up I'm pleased, the real test will come with the first 18 mile trip to work.
Buck
Milly
The Old Girl
Ellie SOLD
Shiro SOLD
Old 07-23-2016, 08:05 PM   #80
preacher anthony
My first vehicle was a 70 Malibu with a 307. I ran a Holley 600 the whole time.
preacher anthony is offline   Reply With Quote
Old 07-24-2016, 09:00 PM   #81
C10_ustacould
Put a few miles on her today with the first long run tonight, 18 miles to work. The new carburetor really does make a difference, no stuttering or stammering while at cruise rpm, just smooth running.
I picked up a TH-350 today. I'll have it rebuilt soon, still need to collect up some supporting parts like a auto steering column and torque converter.
Buck
Milly
The Old Girl
Ellie SOLD
Shiro SOLD
Old 07-31-2016, 12:26 PM   #82
C10_ustacould
Anyone replace a complete dash? Wondering how difficult it is...
Buck
Milly
The Old Girl
Ellie SOLD
Shiro SOLD
Old 07-31-2016, 01:36 PM   #83
smbrouss70
smbrouss70's Avatar
It unbolts on the sides but there are a bunch of spot welds along the lower windshield lip.
Steven
"If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers
R.I.P. Oscar
R.I.P. Ratchet
1967 Pontiac GTO - Dad was the Original Owner
1970 Chevy 2wd SWB "Oscar's Truck"
1970 Chevy 2wd Blazer "Ratchet's Blazer"
2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar"
2017 Chevy Suburban "BDB"
2020 Chevy Blazer Premier "Foxy"
Shop Build
smbrouss70 is offline   Reply With Quote
Old 07-31-2016, 01:53 PM   #84
C10_ustacould
Okay, seems like the risk there is warping the lip (seal retainer).
My dash has a bad repair in the radio area. I have a complete dash hanging in the shed but I'm wondering which repair is easier, the complete dash or the center area I can buy for DeWayne at Nsane Hot Rodz. Either way I'll have to have it painted. The boy wants the ability to listen to FM so I'll need to fix this so I can install one of the retro style radios.
Buck
Milly
The Old Girl
Ellie SOLD
Shiro SOLD
Old 07-31-2016, 02:28 PM   #85
smbrouss70
smbrouss70's Avatar
If you have a complete dash and don't mind cutting it up, then you can cut it like my picture, plus cut between the ovals under the dash pad and graft that into your existing dash. The glove box door, instrument bezel, and dash pad end up hiding most of your welds if they don't come out perfect and you don't have to pull the windshield out. Something to think about anyway.
Steven
R.I.P. Oscar
R.I.P. Ratchet
Shop Build
Old 07-31-2016, 09:10 PM   #86
knomadd
knomadd's Avatar
To me, ^^THIS^^ would be the way to do it. Seems like a whole lot less work and potential for warping/damage of other panels.
-Duane
Old 08-06-2016, 11:06 PM   #87
C10_ustacould
I went to the parts store to pickup a valve cover breather and a new thermostat housing gasket... Walked out with new chrome Edelbrock valve covers, valve cover gaskets, Edelbrock breather, and a thermostat housing gasket. $20 turned in to $75! The worst part is that while they aren't all warped and nasty like to old ones, the engine and engine compartment are so nasty the new ones just blend right in.
Before
and after...
Buck
Milly
The Old Girl
Ellie SOLD
Shiro SOLD
Old 08-07-2016, 09:28 PM   #88
GAc10boy
GAc10boy's Avatar
Nice improvement over the others. Lookin' good.
- Robbie
UNITED BY TRUCKS - classic truck video content
YouTube: www.youtube.com/c/unitedbytrucks
Instagram: @united_by_trucks
Paw Paw '68 508 Dark Blue Custom C10
Teddy '68 GMC SWB 503 Light Green LS Build
Mississippi Mud '75 Skyline Blue Patina SBC Build
GAc10boy is offline   Reply With Quote
Old 08-07-2016, 11:11 PM   #89
C10_ustacould
Someday I'd like to have some factory Chevrolet script valve covers modified for PCV by n2billet or Delmo and some sort of factory style air cleaner. That would be very cool.
Buck
Milly
The Old Girl
Ellie SOLD
Shiro SOLD
Old 09-15-2016, 05:08 AM   #90
C10_ustacould
Put some LEDs in it...
Buck
Milly
The Old Girl
Ellie SOLD
Shiro SOLD
Old 09-15-2016, 10:10 AM   #91
Hart_Rod
Hart_Rod's Avatar
Attachment 1570745
Looks good! Now you just need a trailer hitch back there......:....!
Hart_Rod is offline   Reply With Quote
Old 09-19-2016, 09:55 AM   #92
aggie91
I'm just glad to be here!
aggie91's Avatar
Very nice truck. Doing this way should help keep costs under control.
Love the green too!
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 09-23-2016, 05:44 PM   #93
C10_ustacould
Got the TH-350 back from the transmission shop today. Bought a used auto column, just need to disassemble and paint it, that should be an experience. Also have a Boyd Welding ready to go in, just waiting for Hart_Rod to get back from vacation so he can help with custom side fill.
Buck
Milly
The Old Girl
Ellie SOLD
Shiro SOLD
Old 09-23-2016, 09:23 PM   #94
GAc10boy
GAc10boy's Avatar
Nice parts! Why the 350 instead of OD trans?
- Robbie
Old 09-24-2016, 11:51 AM   #95
C10_ustacould
Much cheaper to build. Not going to be road tripping in this truck so no need to spend the money.
Buck
Milly
The Old Girl
Ellie SOLD
Shiro SOLD
Old 09-24-2016, 06:31 PM   #96
tune_1
Great to see you at work on another truck. The small steps look good.
Dwight
tune_1 is offline   Reply With Quote
Old 09-26-2016, 06:12 PM   #97
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Nice work on the truck, and the trans looks nice. Send Rob up here and have him do my side fill too would ya?
Ryan
1969 Chevy milk truck
Old 09-27-2016, 01:05 AM   #98
NewType72
NewType72's Avatar
Very sanitary build love it!
Project NewType 1972 Chevy C/10 Cheyenne Super ( Daily Driven Showtruck ) http://67-72chevytrucks.com/vboard/s...d.php?t=507903
Project Great Grandpa's Legacy 1973 Chevy C/10 Cheyenne ( Current daily driver collecting big time parts ) http://67-72chevytrucks.com/vboard/s...89#post7084289
- Dylan
(209)-985-7721
NewType72 is offline   Reply With Quote
Old 09-27-2016, 04:12 PM   #99
68Gold/white
The steering column fiasco IS a lot of fun. Just don't force anything. It all fits together....
68Gold/white is offline   Reply With Quote
Old 09-27-2016, 04:56 PM   #100
WarMonger
WarMonger's Avatar
Good looking truck. Think about hard lining the fuel line from the pump to carb. these trucks burn down all the time for that reason and you have a good looking one. Hate to see it go up in flames.
..................... ____
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
1970 C20
-_--_--_- ______
_--_--_- /___|__\____
-_--_-_ |_(0)|__|_(0)]
1972 K5
WarMonger is offline   Reply With Quote
