Old 07-19-2016, 08:55 AM   #1
urmyboyblue
Brake Booster Adapter
My C30 has power brakes on it from the factory, I suppose (I have seen this on other trucks as well). The booster is mounted to the fire wall using an adapter that kicks the booster at an angle to the fire wall. It also has a linkage that connects from the brake pedal to the booster rather than a simple rod. My question is why did the factory do this? Is it for clearance of the valve covers on the engine? Mine is in good shape, so I will reuse it- I am just wondering why the factory did this.
Might as well ask- if the booster is bad on mine, where can I get a repro version or an after market version that will work? I am going discs on all 4 corners.
urmyboyblue is offline   Reply With Quote
Old 07-19-2016, 10:38 AM   #2
cooperhw
cooperhw's Avatar
Re: Brake Booster Adapter
Not sure why the factory did what they did but I am sure there was a good reason, or they would not have spent more money and did it how they did. I had the same set up on my 68 C30 I did last year and got a complete unit from O'reillys auto parts.
"Life is too short to drive a boring vehicle".
Later,
Wayne
cooperhw is offline   Reply With Quote
Old 07-20-2016, 12:09 AM   #3
Captainfab
60-66 Nut
I believe it was done for clearance for the I6 air cleaner. Check with your local auto parts supplier for a replacement brake booster.
Old 07-20-2016, 10:58 AM   #4
Joemomma1
Joemomma1's Avatar
Same here as others have said. O'Reilly had reman available just make sure it specifies w/ horizontal brackets.
Joemomma1 is offline   Reply With Quote
