Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The pre 1947 Chevrolet & GMC Truck Message Board
Old 07-19-2016, 04:08 PM   #51
docrock
docrock's Avatar
Re: My 42 Project
1954 GMC on 93 Silverado chassis http://67-72chevytrucks.com/vboard/s...d.php?t=408344
1942 Chevy 1/2 ton Pickup http://67-72chevytrucks.com/vboard/s...d.php?t=429494
R.I.P. TOM SEFFRON 68 FOUR DOOR http://67-72chevytrucks.com/vboard/s...d.php?t=495438
1942 Chevy that ate my brain 70 Chassis https://67-72chevytrucks.com/vboard/...d.php?t=835250
docrock is offline   Reply With Quote
Old 07-19-2016, 04:29 PM   #52
docrock
docrock's Avatar
Re: My 42 Project
Old 07-19-2016, 04:31 PM   #53
docrock
docrock's Avatar
Re: My 42 Project
Old 07-19-2016, 04:34 PM   #54
docrock
docrock's Avatar
Re: My 42 Project
Old 07-19-2016, 04:37 PM   #55
docrock
docrock's Avatar
Re: My 42 Project
Old 07-20-2016, 07:32 PM   #56
docrock
docrock's Avatar
Re: My 42 Project
I cant believe its almost 6 years. I got to get this thing done and on the road by November
Old 07-20-2016, 07:51 PM   #57
docrock
docrock's Avatar
Re: My 42 Project
This is the master cylinder kit for the 47 to 54. Fits good
Old 07-26-2016, 03:04 PM   #58
docrock
docrock's Avatar
Re: My 42 Project
steering column is up and attached. Added directional switch
Old 07-26-2016, 03:06 PM   #59
docrock
docrock's Avatar
Re: My 42 Project
working on the motor
Old 07-26-2016, 03:07 PM   #60
docrock
docrock's Avatar
Re: My 42 Project
Trying to get the brakes done this week before I start the motor
Old 07-27-2016, 08:43 PM   #61
CHIZZLER
SAVING ONE TRUCK AT A TIME
CHIZZLER's Avatar
Re: My 42 Project
Looking great.
53-suburban (99% done)
40-pick up (99.9% done)
12-cc lb dually D-max (dd)
61-crew cab D-max
"PAY LESS FOR WHAT YOU NEED PAY MORE FOR WHAT YOU WANT"
53 BURBAN BARN FIND:http://67-72chevytrucks.com/vboard/s...d.php?t=404091
1940 PROJECT MOON SHINE:http://67-72chevytrucks.com/vboard/s...d.php?t=551088
1961 CREW MAX: http://67-72chevytrucks.com/vboard/s....php?p=6957999
CHIZZLER is offline   Reply With Quote
Old 07-28-2016, 07:54 AM   #62
paintman
Re: My 42 Project
Attachment 1554499
Attachment 1554500
Hey docrock, I was just taking a closer look at your build. Most everything looks good, but you may want to take a look at how far back you have your master cylinder mounted. In the one pic it looks as if the brake lever is going to hit the floor board when it is all the back.
paintman is offline   Reply With Quote
Old 07-28-2016, 09:50 PM   #63
docrock
docrock's Avatar
Re: My 42 Project
I will check it out tomorrow. I am making a new floor, but i was running into the trans crossmember. Thanks for looking out
Old 07-29-2016, 09:57 AM   #64
paintman
Re: My 42 Project
I have mine mounted about 2" more forward then yours and my pedal just barely rubs my floor in the full return position. I know what you are saying about hitting the trans crossmember. I had to give the top of my crossmember a wack with the sledgehammer so it would not rub the bottom of the master cylinder.
[/URL]
Old 07-31-2016, 08:01 PM   #65
docrock
docrock's Avatar
Re: My 42 Project
Checked it. Lands perfect. I noticed i will have a flat floor and cowl. I am very happy about that
Old 08-03-2016, 04:02 PM   #66
docrock
docrock's Avatar
Re: My 42 Project
So the new radiator got here from Superior. It fits in the holeName:  20160803_124545.jpg
Old 08-03-2016, 04:11 PM   #67
docrock
docrock's Avatar
Re: My 42 Project
Ok so the good thing is it fits in the hole. The holes in the flanges are not pre-drilled. Placement is up to you. I cut an inch off the flange so it would go lower in the radiator support. Gives me more fan cooling surface. Also it gives a little more room for the cap. It comes with the overflow on the correct side. I am not a fan of the angle that the flanges are mounted on but it also is at the same angle as the fan, so better cooling. I like the brass fittings, and the trans lines are sae instead of metric. Overall I like it.Name:  20160803_124603.jpg
Old 08-03-2016, 05:12 PM   #68
docrock
docrock's Avatar
Re: My 42 Project
Old 11-18-2016, 02:46 AM   #69
docrock
docrock's Avatar
Re: My 42 Project
Been a while since I have been on. Finished all the mechanicals and it runs great. I drove it back and forth in the garage. Had the grill chromed. Electrical is started and the basics are done. I am build a standard bed for the truck instead of the flatbed. I am missing rear fenders. Options are 350 each on fiberglass, 1941-46 models. 250 for fiberglass 37-38 fenders. I have not seen any steel fenders anywhere. Dont know that the 37-38 fenders will even work.
I saw a truck with 47-53 steel fenders but don't know how those work either. I have not seen a lower grill valance made out of metal. Might have to make one. Not a fan of fiberglass
Old 11-18-2016, 09:34 AM   #70
solidaxel
solidaxel's Avatar
Re: My 42 Project
When we re looking for rear fenders we bought a complete 37 just for the rear steel fenders............. they did not fit!
The glass ones look great and just need a little support and they will work fine
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 11-18-2016, 02:35 PM   #71
docrock
docrock's Avatar
Re: My 42 Project
Thank you for the info. I knew this site would steer me right.
Old 12-27-2016, 11:19 PM   #72
docrock
docrock's Avatar
Re: My 42 Project
Size:  45.5 KBgot a fender on
Old 12-27-2016, 11:20 PM   #73
docrock
docrock's Avatar
Re: My 42 Project
Size:  39.9 KBlittle park light wakes up
Old 12-27-2016, 11:22 PM   #74
docrock
docrock's Avatar
Re: My 42 Project
Size:  28.9 KBnow the big light. making progress
Old 12-27-2016, 11:23 PM   #75
docrock
docrock's Avatar
Re: My 42 Project
Size:  49.9 KBgot the grill back from the chromer
