Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 07+ Chevy and GMC Message Board
Old 07-20-2016, 04:10 PM   #1
dennislbrooks
dennislbrooks's Avatar
2015 3/4 w/traler package
Does the brake controller move when foot brakes are applied and no trailer is connected? Or does it have to sense a trailer with electric brakes before it moves? Or does it never move unless it is pushed manually? The DIC shows gain adjustment from 0-10 and also a sliding bar I guess showing voltage to trailer brakes --the bar moves but no trailer braking,
I will recheck my trailer but it works as factory wired on my 2006. I have an aftermarket controller that moves with the braking --trailer or no trailer. I may have to take it back to dealer to look at.
1942 Chevy 1/2 ton Rod, 1959 GMC 1/2 ton Fleet Stepside, 1967 Chevy SWB K10, 1985 Corvette Coupe 4+3, 2015 Chevy Duramax reg cab 4WD W/T
dennislbrooks is offline   Reply With Quote
Old 07-22-2016, 07:28 AM   #2
77 ChevySport
Re: 2015 3/4 w/traler package
I have a 2014 Silverado with the factory installed brake controller. My guess is that the controller does not work until it "senses" a trailer is hooked up. The aftermarket controllers have no way to sense if one is hooked up. Larry
77 ChevySport is offline   Reply With Quote
Old 07-22-2016, 02:45 PM   #3
dennislbrooks
Re: 2015 3/4 w/trailer package
My trailer is a dual axle but only one has brakes and I read that the computer has to read enough resistance to acknowledge it has a trailer with electric brakes. I will hook it up again without the truck running and see what the DIC indicates. Supposedly one 12 volt bulb to ground on the trailer brake pin is enough to look like a trailer.
May try it if needed.
tks
Old 07-28-2016, 10:58 AM   #4
67ChevyRedneck
67ChevyRedneck's Avatar
I found this on another forum...
is trailer brakes elec over hydraulic? if so you need to hang a electric break magnet from ground to the breaks wiring on the trailer,(did so in my terminal box and stuck magnet it there as well) this style of system does not draw enough power not running/breaks applied to make the truck think there is trailer actually there. main reason i believe is because its a scr driven system not an old analog style (went through this myself for three or four days along with multiple calls around the country trying to find out wth to do)
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 07-28-2016, 07:03 PM   #5
dennislbrooks
No hydraulics -- just magnets electric. I hooked to my 2006 1/2 ton today and the trailer brakes function correctly hauling a 2001 s10 home in the rain. Next time I hook up to the duramax not running I will see if it sees the trailer. If not I will attempt a test with a 12 lamp.
I went dumb earlier when I asked if the manual button moved with the foot pedal but I know that only works if actually hooked into the hydraulic --like the old kelsey hayes types.
