![]() Join Date: Jul 2016
Reattach drip rail temporarily on 1977 GMC
Hello,
Perhaps in the process of sanding and clear-coating my truck, a previous owner removed and then partially replaced the drip rails around the doors. The passenger side is tacked on with a few screws, the driver side trim is sitting behind the bench seat. I found these threads about reattaching this type of trim. Technical page http://forum.73-87chevytrucks.com/sm...c,24859.0.html Original article: http://forum.73-87chevytrucks.com/sm...?topic=24752.0 My question is, should I go through all this now? I'm enjoying the "As Is Azure" + patina + clear coat + black paint job for now, but I will probably get her exterior painted/restored within a year (budget allowing!). Is there a good way to attach this molding that will allow for easy-enough removal when needed? But if the rail isn't attached flat to the door, does it serve any purpose in the rain? (Not sure why my photos rotated when I uploaded them; the originals are fine.) Thanks! Michelle
=============== "...We won't live forever. Make sure you accomplish what you were put here for.” Abigail Adams (First Second Lady, Second First Lady) =============== 1977 GMC K25 Sierra Classic Long bed "Abigail Amelia" 1986 Jeep CJ7, 1973 Chevy K5 Blazer (Hubby's projects) |
Re: Reattach drip rail temporarily on 1977 GMC
I would throw them back on. If you don't have them while it rains, water will fall down and hit the seat/floor. I used 3M tape and new Stainless screws. I have pictures in my build thread in my signature.
86 c30 crew cab dually 454/400 4/6 drop SOLD 1-8-11 1981 chevy K10 short Bed Scottsdale SOLD 10-26-2020 67 GMC Stepside Straight six/3 on the tree "The Peach" 2020 Silverado Double Cab LT Z71 5.3 8 speed Daily Driver K10 build http://67-72chevytrucks.com/vboard/s...d.php?t=671934 The Peach build http://67-72chevytrucks.com/vboard/s...d.php?t=733903 ![]() |
^^ what he said. I use a 5/16 (I think) wrench to remove/ replace the screws. You don't mangle anything that way. Put the seal tape on and start each screw a couple turns and start in the top corner and go down and forward with the screws. It's easy to manage that way and lay it flat. A small socket on it is too tight or a Phillips doesn't work too well either
-Cody |
Tags |
1977 gmc, drip rail, molding |
