Old 07-27-2016, 06:05 PM   #2101
Ta2Don
Ta2Don's Avatar
Re: Donz '65 SWB Stepper Budget Build...
Originally Posted by Grizz1963 View Post
You certainly are all over it now Don.
Looking great.
Thanx Mate...Cheers!!!
Originally Posted by Bomp View Post
Way to be on it. Even through the heat.
Thanx Greg!!! Diggin' the arrows and skin!!!
Originally Posted by rusty76 View Post
Friend of mine lives in Siberia. The weather is a lot cooler right now than here. Lol. But I'll pass on winter there. Brrrrrrrr. But summer seems nice.
Winter in Siberia... Nooooo Thank You!
DON
Proverbs 27:17
US Air Force Retarded errr Retired
My '65 Stepper Build:http://67-72chevytrucks.com/vboard/s...d.php?t=533920
My '60 Rusty Patina Build:http://67-72chevytrucks.com/vboard/s...66#post7402266
My '72 http://67-72chevytrucks.com/vboard/s...59#post7204359 SOLD
Ta2Don is offline   Reply With Quote
Old 07-27-2016, 06:18 PM   #2102
Ta2Don
Ta2Don's Avatar
Friday was productive...
I was able to get the Alternator wiring complete... and in the process thought, I need to test this one to see if it even works... It was included in the Serpentine belt setup I bought a few years ago... Results......... No work!!! at least I have a core for replacement, as it's the same price to purchase a remanufactured unit with a lifetime warranty as it is to have it rebuilt locally with a 3 month warranty... easy math even for me...
Off today and tomorrow, so why not jump into the Brake lines...
After locating all my parts and pieces, it was off to the parts store to return 2 hoses previously purchased and get the correct one as well as some brake lines complete with fittings...
Here's the result of the first trip...
Untitled by Donald Olivo, on Flickr
Here's the rubber hose that will feed the lines to each wheel cylinder...
...and a shot of the line feeding the driver's side wheel...
I was planning on getting a bit further today, but a thunderstorm seemed a good enough reason to find my way to my recliner and vegetate in front of the telly for a bit... also gives Jojo a place to hide from the thunder...
More Brake line work tomorrow, and I may even try to get energetic enough to redo the rear brakes, especially replacing the wheel cylinders...
til next time guyz and gals!!!
DON
Proverbs 27:17
Old 07-27-2016, 08:14 PM   #2103
clemdaddy
clemdaddy's Avatar
nice work Don… I also like that green brake line, bends so easy, no tools required.
Tomorrow is a good day for brakes…
It funny how dogs are afraid of thunder. My 2 big ol' shepherds hide from storms. Hope the boogie man doesn't make loud thunder sounds.
clemdaddy is offline   Reply With Quote
Old 07-28-2016, 03:25 AM   #2104
Grizz1963
Grizz1963's Avatar
Thanks for the updates and chat Don.
As Clem says, these brake lines are another cheap, sensible thing to replace on our trucks.
50-ish year old brake lines probably can do e
With it.
MY BUILD LINK: http://67-72chevytrucks.com/vboard/s...585901]Redneck Express - 1966 C10 Short Fleetside
MY USA ROADTRIPS http://forum.retro-rides.org/thread/...2018-humdinger
IF YOU CAN'T FIX IT WITH A HAMMER, YOU'VE GOT AN ELECTRICAL PROBLEM MATE.
Grizz1963 is offline   Reply With Quote
Old 07-28-2016, 08:55 PM   #2105
Ta2Don
Ta2Don's Avatar
how am I supposed to sleep now that I can't count on jojo to wake me up if the boogeyman visits? I sleep good with thunder sounding...
With it.
Always a pleasure chatting mate! due to many Honeydooz and a visit to a friend's new shop no truck time today... I was able to pick up another needed line and also hook up Bret with some brake line part numbers...
DON
Proverbs 27:17
Old 07-29-2016, 12:19 AM   #2106
TJ's Chevy
TJ's Chevy's Avatar
Looking good brotha! The 100 degree weather here has been taking my motivation to sand blast away. haha!
Old 07-29-2016, 06:26 AM   #2107
Ta2Don
Ta2Don's Avatar
Thanx Brotha!
Yesterday's feel like temp hovered around 103F and the past week or so has been in the 105 to 115F range, serious motivation killer!!!
Working today and tomorrow with Sunday and Monday off, planning on finishing up Brake plumbing by Monday evening...
DON
Proverbs 27:17
Old 07-29-2016, 10:34 PM   #2108
ChrisDollins
ChrisDollins's Avatar
Definitely! You get drenched in sweat before you even get to work on the truck! Me and Carson worked on the GTO yesterday, but we took many A/C breaks and drank lots of water. You're making good progress man, it'll be on the road real soon.
Chris
ChrisDollins is offline   Reply With Quote
Old 08-01-2016, 09:31 PM   #2109
Ta2Don
Ta2Don's Avatar
Well another job 95% complete...
Spent yesterday and today plumbing the brakes... In-between Thunderstorms...
Started at the back, cleaned up the plungers for the wheel cylinders and installed the new ones in order to run the lines...
Although the last pic doesn't show the completed line connection, it is now complete, Master cylinder to wheel cylinders, still gotta fab a bracket for the rubber line...
Today was the front... that is, after a trip to Little Rock for my wife's routine Doctor appt, then Truck time... As soon as I got the front end up in the air, and climbed under and got the R/side line bent and started getting the tee connected... another quick afternoon T/Storm popped up...
Slowed me down for about an hour, then back after it... All of the hard lines, Front to Rear are plumbed, and ready for bleeding once I get the rotors turned, and the rear shoes replaced... Other than that, I need to secure the lines and finish up protecting the Wiring harness to the rear... Also a good time to mount the Fuel filter and pump back near the tank...
Used a paint can to coil the lines coming from the Proportioning Valve...
Pass/Side line...
Driver's/Side back to the tee...
Another shot of the tee, I took the line past the tee and looped back to facilitate easier servicing down the road. The tee is right at the back of the crossmember, so hooking the line up from the rear made sense to me...
Caliper in place, waiting on me to modify the end to work with the drop spindle... As it is, the end that bolts to the caliper is bent in a way that will run the rubber hose into the upper ball joint... after turning the rotors, this week, I'll address that mod...
As I draw closer to driving this for the first time, the little things still needing attention seem to add up... Gotta make a list...
Til next time...
DON
Proverbs 27:17
Old 08-02-2016, 03:03 AM   #2110
mjh1965
mjh1965's Avatar
Well done Don you'll soon have it on the road , and driving it to Clem's this year .
FINALLY PUTTING IT BACK TOGETHER AT LONG LAST
MY BUILD THREAD:
http://67-72chevytrucks.com/vboard/s...d.php?t=611614
mjh1965 is offline   Reply With Quote
Old 08-02-2016, 09:47 PM   #2111
Ta2Don
Ta2Don's Avatar
After work today, I wrapped the wiring harness feeding the rear in a split loom with the lights wires exiting the rear driver's side frame rail and the Fuel Pump and sending unit wire exiting the loom a bit earlier in the run...
I also mounted the fuel pump and pulled the rotors so I can turn them at work tomorrow...
After some online research, I determined this tank is a LMC offering... Seems it's a 21 gallon side fill version. It was with the truck when purchased and unfortunately, no sender or paperwork can be found...
Lastly, I called LMC attempting to figure out what function the fuel tank ports serve... Wasted that phone call as LMC offers ZERO tech support...
This is a photo of the driver's side of the tank... I believe the center port, just to the left of the fill tube is the vent, and the one to the left of that I am unsure of...
This is a photo of the right side , the small port on the side has me confused... it is directly opposite of the smaller fitting on the Driver's side... Looking through the sender hole I cannot see any tube that would draw from the bottom...
I will be ordering the sender soon and the pic on the website isn't very helpful, but it looks like there is a pickup tube with a screen attached... so any help is appreciated as to the function of these ports...
DON
Proverbs 27:17
Old 08-03-2016, 04:22 AM   #2112
Grizz1963
Grizz1963's Avatar
Really moving on now ehhh Don.
Great to see your progress.
Old 08-03-2016, 08:50 AM   #2113
clemdaddy
clemdaddy's Avatar
dude... you're a madman on a mission. keep after it bro.
Old 08-03-2016, 10:40 AM   #2114
White knuckle Garage
White knuckle Garage's Avatar
looking good bro
White knuckle Garage is offline   Reply With Quote
Old 08-03-2016, 01:23 PM   #2115
likaroc13
Rollin' Old Skool
Man, you're about to be driving this thing...I'm getting excited for you!
Phillip
My Build threads:
1966 Chevy C-10 "Black Betty"
Pics:
Previous Rides:
Old 08-04-2016, 06:45 PM   #2116
realvc
realvc's Avatar
Hey Don, you're moving right along.
The big port next to the fill is a fill vent that runs up to the fill spout, one of the smaller ports might be a vent port to a canister and the other small port might be a return port. I've not seen your fuel sending unit but some times they have the fuel pick up tube and filter/screen/sock attached.
If you're using an in tank fuel pump and sending unit the vent and return may be built into that unit.
Good luck on sorting it all out, I know you can do it.
Take care.
Vince
Galatians 6:14
62 SWB stepside, 94 Wrangler, 99 Z71, 99 vette
My Project http://67-72chevytrucks.com/vboard/s...d.php?t=719086
"If it's too loud, you're too old"
realvc is offline   Reply With Quote
Old 08-08-2016, 05:58 PM   #2117
Ta2Don
Ta2Don's Avatar
Thanx Guyz!!!
Another few items either finished or nearing completion...
This weekend found me focusing on Brakes... It's good to be able to stop...
I started off by getting the Front brakes finished up first, earlier in the week I turned the rotors and then after re-installing them I modified (Bent) the hoses. They had a 90 degree bend which had them pointing directly into the Upper Ball joint thanks to the 2 1/2" Drop Spindles... Some Vise grips and an arm work out have them now mounted and bolted in place...
New pads installed...
Yesterday, after getting the second caliper bolted in place, a typical afternoon thunderstorm kicked up stopping the rear brake work... The rears had to be done with the truck in the Sunshine...
Today my focus was getting the rear brakes complete and ready to bleed the system...
Here's the second rebuilt Drum set up just before re-installing Drum and Tire...
So, after a trip into town for some parts I neglected to purchase, fuel line, and a hose to connect the Booster... JoJo and I spotted a hawk with a fresh kill along the road...
Just after I snapped that pic, JoJo decided to bark... and the hawk flew into the trees...
Booster hose in place...
Truck getting some rays...
A while back, a year or more, MarkeB01 offered some parts for the asking...
He listed the items up for grabs and after all was said and done he hooked me up with a few items, including a fuel pressure regulator gauge as well as an isolator... Here's the gauge in it's temporary home under the dash...
I still need to grab some fittings to finish the install... Thanks Again Mark!!!
Brakes are ready to be bled, so is the clutch hydraulic system... Closer and Closer...
Ordering my Fuel Sending unit soon, still need to get another alternator too...
DON
Proverbs 27:17
Old 08-08-2016, 06:01 PM   #2118
dwcardfan
dwcardfan's Avatar
Your kicking it Brother!!!
dwcardfan is offline   Reply With Quote
Old 08-08-2016, 06:17 PM   #2119
rusty76
rusty76's Avatar
Looking good Don! I can't wait to see you scootin around.
http://67-72chevytrucks.com/vboard/s...d.php?t=581873
The low buck build threads. Check'em out!
http://67-72chevytrucks.com/vboard/s...d.php?t=666022
My build thread
Crossmembers CC
rusty76 is offline   Reply With Quote
Old 08-08-2016, 09:03 PM   #2120
TJ's Chevy
TJ's Chevy's Avatar
Diggin the progress brotha!
Old 08-09-2016, 02:07 AM   #2121
Grizz1963
Grizz1963's Avatar
Brilliant pics of the Kestrel Don, thank you for sharing.
That made my day yesterday.
Great storming progress again.
Old 08-09-2016, 05:10 AM   #2122
Looking good Don!
Old 08-09-2016, 06:32 PM   #2123
realvc
realvc's Avatar
You and your truck will be on the road soon.
Looking Good, Keep on Truckin'
Vince
Galatians 6:14
Old 08-09-2016, 10:12 PM   #2124
Bomp
Bomp's Avatar
Excellent progress
Bomp is offline   Reply With Quote
Old 08-21-2016, 04:24 PM   #2125
Ta2Don
Ta2Don's Avatar
Looking good Don!
Excellent progress
Thanx Guyz... After 8 straight days with rain... we finally got a couple of days that are forecast to be rain free as well as cooler and drier air...
Getting' some truck time in, so update later... Here's the temp at 2pm this afternoon in the shed... not 100F
DON
Proverbs 27:17
65 swb, c10, step side, tattoo
