Old 07-28-2016, 01:19 PM   #1
SaltH2OHokie
Removing behind seat fuel tank brackets
Howdy,
I bought a newer seat for my '66, from which previous owner had already removed cab mounted tank, and when I pulled old seat yesterday realized I still have big ole brackets back there. Since one of the bolts holding the bracket on each side is a body mount bolt, I assume I'll need to put something back more substantial than just a standard nut and washer? Should I cut some plate and fashion a backing plate for the floor of the cab, or just a fender washer, or I pondered cutting out a portion of the bracket and tacking it down to the cab floor and using the factory captive nut.
Any suggestions? Am I over thinking it and I should just stick a nut on it and move on?
Ryan
SaltH2OHokie is offline   Reply With Quote
Old 07-28-2016, 02:05 PM   #2
Sik5chevy
Re: Removing behind seat fuel tank brackets
Check out racecougar build thread, he cut his and welded a piece of metal in its place. His build has helped me alot http://67-72chevytrucks.com/vboard/s...d.php?t=560434
Sik5chevy is offline   Reply With Quote
Old 07-28-2016, 06:31 PM   #3
SaltH2OHokie
Thanks. I'm hoping to remove the bracket entirely. I've already removed the driver's side...I think I'm going to weld some nuts to some 3/16"x 2" steel and bolt the body mount and the other bolt from underneath back in let the steel serve to spread any load.
Old 07-29-2016, 07:24 PM   #4
SaltH2OHokie
Drivers side out... Going to clean up rust, weld up no longer used holes, and make a backing plate for body mount.
Old 07-29-2016, 11:58 PM   #5
Sik5chevy
Cool let me know how it turns out
