Old 07-28-2016, 08:38 PM   #1
1970 CST Short Wide
Senior Moment
1970 CST Short Wide's Avatar
What are you using for throttle cable
What are you LS guys using for a throttle cable ?? My original one obviously won't work. Does anybody after market make one ??
1970 CST LS 1 6 speed Ford 9 inch Detroit Tru Track, Dakota Didgital, Vintage Air, QA1 Coil Overs Front & Rear Lots of FUN
2013 GMC PU, Oldest Son
71 GMC LWB. QA1 Suspension, Angry SB. Youngest Son
2017 Toyota SUV Daughters car
2018 Traverse , Wife’s Ride
Pittsburg Ca
94565
1970 CST Short Wide is offline   Reply With Quote
Old 07-28-2016, 09:13 PM   #2
mongocanfly
mongocanfly's Avatar
Re: What are you using for throttle cable
I used the cable from a 01 truck on my 81...had to file the firewall hole a little bit but it worked perfect.
Old 07-28-2016, 09:32 PM   #3
1970 CST Short Wide
Senior Moment
Unhappy Re: What are you using for throttle cable
My Truck is a 70 but it's worth a try, thanks
Lokar is expensive
Pittsburg Ca
94565
Old 07-28-2016, 10:12 PM   #4
mongocanfly
I think I gave 5 bucks for it at a junkyard..I just held a piece of paper up to the firewall and traced a pattern for the firewall hole and transferred it to my 81 over that cable hole and then opened what needed removed with a file..the ls cable just snapped in place..my gas pedal was already a cable pedal..if yours is a rod type you might want to grab the pedal to..
Old 07-29-2016, 12:09 AM   #5
1970 CST Short Wide
Senior Moment
I already switched over to cable when I had injection on the BB. I work at an auto parts store, I'll see if they can get it. If not I'm off to the wrecking yard
Steve
Pittsburg Ca
94565
Old 07-30-2016, 11:13 AM   #6
roundhouse
my truck is 76-ish we used the cable that came with the 2002 engine
the metal cable was a little bit to long where it hooks to the gas pedal and I just looped it around a 9mm socket and used a cable clamp to take up the slack.
roundhouse is offline   Reply With Quote
Old 08-05-2016, 10:33 AM   #7
Matt Cramer
Mountain bike brake cable here.
Matt Cramer
1972 Chevy C10 - 4.8 swap, long bed, and maybe one dent free body panel somewhere - SOLD
4.8 LS build thread
Matt Cramer is offline   Reply With Quote
Old 08-06-2016, 12:01 AM   #8
1970 CST Short Wide
Senior Moment
Found exactly what I needed at the wrecking yard. LOL Ca price $20
Thanks all for your input
Pittsburg Ca
94565
