Old 07-29-2016, 12:46 AM   #26
57taskforce
All about them K’s
57taskforce's Avatar
Re: How to delete the external voltage regulator?
The one wires don't always charge the best at low rpms. The 3 wire internally regulated units do not have this problem.
Tyler
57taskforce is online now   Reply With Quote
Old 07-29-2016, 12:51 AM   #27
VetteVet
Msgt USAF Ret
VetteVet's Avatar
Originally Posted by dmjlambert View Post
Is there a different way the one wire alternators are done? The link appears to talk about 3 wire alternators. Advantages/disadvantages for one wire vs. 3 wire?
Is it only the one wire alternators that won't start charging until revved to a certain RPM, or all internally regulated ones that way?
Well I'll take a chance again,
Paragraph three
http://www.madelectrical.com/electrical-tech.shtml
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Old 07-29-2016, 01:59 AM   #28
dmjlambert
dmjlambert's Avatar
Thanks. I am soaking this up and learning.
Old 04-09-2018, 01:05 PM   #29
72blazerblue
72blazerblue's Avatar
Paragraph three
VetteVet, I have been reading on this the past couple of days and still haven't quite found what I am looking for.
I have a 1990 TBI that I am installing in my 67 c10. The alternator from the TBI engine is a factory single wire CS style alternator.
The above link seems to point out the obvious advantages of the 3 wire SI alts over the 'aftermarket' 1 wire SI alts?
I have not seen anyone specifically say anything about the factory CS 1 wire alternator. If it was put on these TBI engines from factory shouldn't it be still much better than any SI alternator?
1967 SWB C-10
1972 Blazer 4x4
2011 Silverado
72blazerblue is offline   Reply With Quote
Old 05-16-2022, 08:47 AM   #30
Canadian 72 C15
Originally Posted by MARKDTN View Post
Basically blue wire to terminal 1, the white wire to terminal 2. At the regulator plug, jumper the inner 2 wires together and the outer 2 wires together.
I did this exact same thing. Two two jumpers with spade connectors. The two Inner wires and two outer wires on the regulator plug but now I have a draw on the battery and it’s going dead fast. I also saw someone say 1 and 3 need to go together and 2 and 4. Any ideas guys?
Canadian 72 C15 is offline   Reply With Quote
Old 05-16-2022, 10:20 AM   #31
MARKDTN
Terminal 2 should have battery voltage at all times. Terminal 1 is the trigger. It comes from the dash basically through the ammeter or Gen light. If there have been no dash changes then it should work as a 3 wire setup. Some people wire terminal 2 directly to the big lug on the back of the alternator, but if it has a battery source it is supposed to work better. Use a multimeter and see if with engine off you have battery voltage on the terminal 2 wire. They may be reversed.
Edit
After careful look at a diagram, I did have that wrong. It should be brown wire jumpered to white on #1 for the trigger and orange wire jumpered to blue for battery voltage on #2. Sorry about that.
I think in the old days we switched function on the 2 small wires, but now I would not do that as it makes it harder to diagnose somebody elses wiring mess. Leaving the colors as GM intended them makes later diagnosis by somebody new much easier. I tried to go back and fix the original post but it is too old to edit.
'83 K20-TPI
'73 C10
'79 C10-ex-diesel(SOLD)
'07 Tahoe(Son driving)
'14 Suburban-DD
'71 C10-current project
MARKDTN is offline   Reply With Quote
Old 05-17-2022, 09:11 AM   #32
72SB
IMHO, 3 wire using a solid state external regulator (Tuff Stuff) vs 1 wire alt swap.
My 72 came with a 1 wire conversion....I switched it back to 3 wire. Also if running a Pertronix or HEI dizzy with a 3 wire alt, use the solid state VR
72SB is offline   Reply With Quote
