Old 07-29-2016, 09:10 AM   #26
jams97355
Re: Low vacuum for brakes
I got the hydroboost installed yesterday. It fits in the same space as the vacuum booster with little modification. The lines on the donor van were way too short so I had new ones built. The pedal was too high so I adjusted that. The thing works great. I drove it on the street in front of my house to test it. I couldn't be happier with the results. Thanks for all the input. Next, on to paint, hopefully.
jams97355 is offline   Reply With Quote
Old 07-29-2016, 09:24 AM   #27
solidaxel
solidaxel's Avatar
Thanks for the update
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 07-29-2016, 01:45 PM   #28
mongocanfly
mongocanfly's Avatar
Good to hear...now you can whoa and go..
Old 07-31-2016, 06:30 PM   #29
b00sted
b00sted's Avatar
[quote=jams97355;7660740]
Originally Posted by b00sted View Post
Here you go. Works well and saves some money.
Have you used one? I have almost no vacuum now and wonder if it will be enough.
Yes I have used it on my turbo and procharged cars with no issue. It stores your vacuum for you so you can brake. Yes if you are road racing it will not be for you. But for a car for the street it works well. You can spend a ton of money on a hydro or vac pump setup if you have the money and yes they work well.
1949 Chevy 408 CID stroker 6.0l with a few add ons, 4l80E, 4 Wheel Disk Brakes and a set of GT35 going on soon.
b00sted is offline   Reply With Quote
