07-29-2016, 10:03 PM | #1 |
Rebuilding C20 Stock Power Steering?
Anyone familiar with all that goes with factory power steering on a '67? I'm not used to all of this and Hanes only has pump and power steering gear - not all the extra valve and cylinder.... Who has parts for this to repair or replace as needed. Truck is '67 Chevy C20 3/4 ton Camper Special.
Thanks in advance for any assistance. R/ DJ |
07-29-2016, 10:43 PM | #2 |
Re: Rebuilding C20 Stock Power Steering?
I have this restored on my 67 1/2 ton. I got all the pieces to restore mine from lares Corp. They had every thing but the hoses which I found on ebay.
07-29-2016, 10:49 PM | #3 |
Thank you, checking that out now.
07-29-2016, 10:54 PM | #4 |
A lot of these parts are exactly the same as corvette ( except hoses). Now being you have a 3/4 ton I think that the ball joint at the end of the ram has a bigger shaft size so make sure not to discard yours. It is remove able and can be switched with one from a 1/2 toń or vetted.
07-29-2016, 11:05 PM | #5 |
Rock Auto I found carries Lares steering parts. I do have both Chassis Service & Overhaul manuals. Both valve & control cylinder look rebuildable?
07-29-2016, 11:07 PM | #6 |
I did rebuild my valve. It's fairly straight forward. I bought the ram already done so I'm not sure on that.
07-30-2016, 08:09 AM | #7 |
Ram is exposed to corrosion - so I may just change that too. Thank you for feedback.
07-30-2016, 12:08 PM | #8 |
To protect the chrome shaft I used a rubber from a mustang ram. I hope it saves it from getting pitted up.
07-30-2016, 01:24 PM | #9 |
Good idea - I remember that from my '66 Mustang power steering. ;-)
