Old 07-30-2016, 09:04 PM   #4401
RodsGreen10
RodsGreen10's Avatar
Re: Restoring Rusty
delete
RodsGreen10 is offline   Reply With Quote
Old 07-30-2016, 09:04 PM   #4402
RodsGreen10
Re: Restoring Rusty
If you don't want drone scrap those junk ass blowmasters. And buy some real mufflers.
Old 07-30-2016, 09:05 PM   #4403
Gregski
Gregski's Avatar
Re: Restoring Rusty
Originally Posted by RodsGreen10 View Post
If you do t want drone scrap those junk ass blowmasters.
Trust me I am at the end of my rope with them, what do you recommend? I like deep rumble sound
Gregski is offline   Reply With Quote
Old 07-30-2016, 09:08 PM   #4404
RodsGreen10
Re: Restoring Rusty
Borla. I run the Borla XR1 race mufflers. I have a bunch of videos on YouTube with sound clips idle driving. I am a Borla fan. I run the longer version has a deeper sound.
Old 07-30-2016, 09:16 PM   #4405
rusty76
rusty76's Avatar
Re: Restoring Rusty
I've had glass packs on my truck for eons and honestly they've never droned on me. The only thing I see I would do different on yours is to point the tips (ends of exhaust) toward each other slightly. Like twenty degrees or something. It helps cancel the sound waves. It's the way mine were done. They stop right before the axle. I'll be redoing my exhaust for sure but however what I had worked great and sounded awesome.
http://67-72chevytrucks.com/vboard/s...d.php?t=581873
The low buck build threads. Check'em out!
http://67-72chevytrucks.com/vboard/s...d.php?t=666022
My build thread
Crossmembers CC
rusty76 is offline   Reply With Quote
Old 07-30-2016, 09:17 PM   #4406
Wide Open
Re: Restoring Rusty
Resonators on the late model stuff is after the muffler very near the exhaust tip. Wonder if that would take care of it?
Maybe also try some turn outs?
1972 K10
1986 K30 crew cab dually
2002 Z06
2007 Escalade
Wide Open is offline   Reply With Quote
Old 07-30-2016, 10:25 PM   #4407
Gregski
Gregski's Avatar
Re: Restoring Rusty - Digital Volt Meter Gauge
so added the new Summit digital Volt Meter gauge in the upper left
hope to add the digital fuel gauge next month to complete the Quartet
baby steps folks, baby steps
Old 07-30-2016, 10:28 PM   #4408
Gregski
Gregski's Avatar
Re: Restoring Rusty
and shoved the new Air Fuel Ratio AFR Gauge in the upper right, this is a temporary placement until I get the Vacuum gauge (that's what the second hole is for - forward thinking folks) and then will make it look more better, but still in the same general location
Old 07-30-2016, 11:19 PM   #4409
bhc41051
bhc41051's Avatar
Re: Restoring Rusty
I hear John Deere corn head grease is good for steering boxes. I'm pretty sure power steering and air conditioning are aimed at the "pantie-waist mama's boys" market .
bhc41051 is offline   Reply With Quote
Old 07-31-2016, 01:18 AM   #4410
SkinnyG
SkinnyG's Avatar
Re: Restoring Rusty
1. You don't fully own a project until you've bled on it.
2. You know you are a man when you look down, see blood all over the place, and your first thought is "geez I sure hope that's not mine."
3. I have Dynomax Super Turbo 17748 mufflers on mine, because I'm not 16 anymore, and I can't stand drone. I'd probably get a shorter body muffler though - these are almost too quiet.
1961 Apache: "Grabber Orange" Shortboxed, pancake, step-notch, air-ride, turbo, LS
1977 Silverado: Shortboxed & dropped, potato-potato
V8 Pontiac Firefly (Chevy Sprint): The ultimate engine swap: 5.7L in a 1.0L bag
Lotus Super 7 Replica: Scratch-built street-legal rollerskate
SkinnyG is offline   Reply With Quote
Old 07-31-2016, 10:39 AM   #4411
Gregski
Gregski's Avatar
Re: Restoring Rusty
Originally Posted by SkinnyG View Post
... I have Dynomax Super Turbo 17748 mufflers on mine, because I'm not 16 anymore...
best come back ever!
Old 07-31-2016, 04:22 PM   #4412
Gregski
Gregski's Avatar
Re: Restoring Rusty
so got the oil pressure installed, not sure why it's reading 5 PSI with the truck off but 61 PSI with it warming up sounds good
also got a volt meter wired up, 12.4 volts with the key in the auxilary position, and 14.1 ish with the truck running
man this iPhone camera just can't grasp the concept of focus when it comes to shooting these there green digital read outs
Old 07-31-2016, 04:45 PM   #4413
Gregski
Gregski's Avatar
Re: Restoring Rusty
got the oxygen sensors installed and the new AFR Air Fuel Ratio DLG-1 dual gauge calibrated
more details can be found in the thread below:
INNOVATE DLG1 Wideband O2 Oxygen Sensor Tuning Diagnostics Logging Air Fuel Ratio etc
Old 08-01-2016, 07:34 AM   #4414
Speed2acer
Thumbs up Re: Restoring Rusty
Great timeline posts. I'm just starting a 78 Cheyenne stepside resto and your info has helped greatly. Thanks for such a detailed post!
Speed2acer is offline   Reply With Quote
Old 08-01-2016, 02:58 PM   #4415
Chrispbrown36
Re: Restoring Rusty
It had been a while since I had read through your build, so I decided it was time.
Man I am jealous of the pick and pulls you have in your area. We were down in Nashville a couple of weeks ago (2 and a half hours away) and there were three and I thought I had found heaven. Ended up between the three there was one....that's right one.....square body on their lots. There was an 84 that was but a shell. Locally, one pick and pull and no squares...in fact nothing under the early 90's....at least truck wise. The local junk yards want an arm and a leg for everything. I live in a wasteland of square parts.
Chrispbrown36 is offline   Reply With Quote
Old 08-01-2016, 03:10 PM   #4416
68Timber
I know the pieces fit
68Timber's Avatar
Re: Restoring Rusty
They've dried up here as well. I used to go to the pick and pull just to walk the yard and browse but for the last year or so there hasn't been a square on the yard period.
John
79 2wd Blazer (Bruiser)
85 M1009 Blazer (Sarge) build
74 Honda Z50 build
Old 08-01-2016, 03:20 PM   #4417
Chrispbrown36
Re: Restoring Rusty
There are two squares (one sitting in my neighbors garage and one sitting in a pole barn up the road) that haven't moved in at least 5 years (that's how long we have been here). The neighbor that has the one in her garage....well she and I aren't exactly best friends or I already would have talked to her. The one in the pole barn...I have stopped multiple times and can never catch anyone at the house. I am hoping eventually I will catch someone and be able to get a new parts truck or a new project. Otherwise I am going to have to travel to hit up pick and pulls.
Old 08-01-2016, 07:06 PM   #4418
Gregski
Gregski's Avatar
Re: Restoring Rusty
thank you for the kind words, please document your build and take pictures, if for nothing else to sit back one day in your rocking chair with your granddaughter on your lap and look at them and go damn I did that?
Old 08-01-2016, 07:07 PM   #4419
Gregski
Gregski's Avatar
Re: Restoring Rusty
Bro, things have changed fast, now I go to the four local yards and every once in a while there aint even one Squarebody to pull parts off of, for real even here in sunny Northern California
Old 08-01-2016, 07:08 PM   #4420
Gregski
Gregski's Avatar
Re: Restoring Rusty
ditto, things are disappearing is Sacramento California yards as well, trucks be gettin' famous, time to start building Crown Vics, ha ha
Old 08-01-2016, 07:12 PM   #4421
Gregski
Gregski's Avatar
Re: Restoring Rusty
...The neighbor that has the one in her garage....well she and I aren't exactly best friends or I already would have talked to her...
Two Words: Say it with Flowers!!!
seriously man no woman will say no to flowers, show up looking semi clean, buy some flowers, say excuse me ma'am I was no where in the neighborhood and decided to stop by, would you mind if I was to admire that truck of yours... and thats that, no offers, no pressure no ctiticism, this is just a Hello there neighboor visit, that's a nice truck ma'am, thank you for letting me look at it, have a nice day
you're welcome, ha ha
Old 08-01-2016, 07:26 PM   #4422
Chrispbrown36
Re: Restoring Rusty
Or I could just flag her down one of the times she drives by our house at 2 miles per hour watching to see what we are doing so she can call our landlord....ya she is one of those...
Old 08-03-2016, 02:18 PM   #4423
Will206
Re: Restoring Rusty
I hadn't looked in a while, had to come back and catch up on 10 pages. Looking great, as always Greg.
A couple of things...
I am in a similar situation on mufflers. I got pretty cheap welded Thrush mufflers. Previously this motor had stamped, bottom barrel turbo mufflers and it sounded pretty good, I can't see how this won't be an upgrade, but I too am a little concerned with drone, especially with long tube headers.
Also, I might just go have them welded, I am not convinced me or my harbor freight welder are up to the task.
I also have the same package from Innovate. I just wanted to be able to fine tune this thing ensure optimum A/F, I say good call.
I also have a related gauge package. I have elected to delete all the factory gauges and put together a $200 kit from Intellitronix, which gives me all digital gauges. They look very similar.
Here's a quick video of its first idle:
https://youtu.be/AKEP61owQ7M
Will206 is offline   Reply With Quote
Old 08-03-2016, 02:23 PM   #4424
Will206
Re: Restoring Rusty
Here's a youtube video of someone with the Intellitronix gauge set I have in a square:
(Mine are blue though)
https://www.youtube.com/watch?v=jj12ez_KXHk
Old 08-03-2016, 02:35 PM   #4425
Gregski
Gregski's Avatar
Re: Restoring Rusty
Thank you so much, glad you swung back by Will
LOL, aint that the truth, having graduated from the College of Cheap Harbor Freight Tool Knowledge myself, I have this bit of wizdom to offer
first I hope you have their MIG or at least Flux Core / MIG combo machine and not just their Flux Core unit, (don't know what you got, ok, are you using a gas tank with your box or no tank? no tank means Flux Core)
so one thing that really transformed my HF MIG machine was tossing their cheap spool of wire that it came with and right away going to Home Depot and buying a spool of Lincoln name brand .030 wire, if I was to do it again I would got even thinner wire like the Lincoln .025 to ensure I would weld and not burn holes in the exhaust
then it is just a matter of figuring out your box settings, and honestly you play more with the heat knob ie amps than the wire speed, you set the wire speed to a low setting like a 2 and then just mess with the heat knob until the wire actually penetrates the metal and you can't tap the weld bead off with a hammer, if you can take a hammer and knock the bead off than the wire feed is too cold and you need to up the heat, also if it is popping it is too cold and the wire is bouncing off the metal, tap tap tap instead of melting into it
see what you have made me do, you made me get up on my welding soap box, sorry, hope that helps though
P.S. also an auto darkening welding helmet is a must especially for beginners the nod your head to make the old style helmets fall over your face was cool in the 50's ha ha
