#351 |
Re: Project "Redemption" 68 SWB Fleetside
Sorry to hear about the wheels. That's a bummer for sure. I hope you get it figured out. Is there any possibility that it could be a tire issue?
#352 |
![]() Join Date: Dec 2006
Thanks guys, I was so disgusted yesterday I couldn't even look at the truck let alone work on it! I don't know if it's a tire issue or not, both tire shops said its the wheels and not the tires but I'm no expert so I don't know! I can tell you this, both billet specialties and Newstalgia wheel are lucky they aren't open on Saturdays because I would have been a bit of a lunatic on the phone! I really don't know what I'm going to do now! I guess I'll figure it out tomorrow when I talk to them!
Keith 66 Suburban Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361 IG: bennett68c10 |
#353 |
Sorry to hear about that Keith. I remember reading (might be your thread or another...) this is a problem for another wheel company. It seems as though the hoops are supplied by another manufacturer and the wheel companies supply the center and mount them together. That hoop manufacturer would be the problem, from what I see.
If you really want this style of wheel, I'd ask them to re-hoop your wheels and verify a tire can be mounted on all of them before sending them out. If that's not what you want to do, and you'd be just as happy or happier with a different wheel, send them back to BS and get the other wheels. Just a suggestion as this is probably what I would do, once I was calm enough to call them. GOOD LUCK!
-Duane C/10 Club Texas member 1971 Chevy C10 "Brutus" SWB Fleetside 2016 6.0L (L96) 6L90E (driver/project) 1965 Pontiac GTO "Royal Goat" 400/TH400 w/AC (my baby) |
#354 | |
#355 |
Keith I would be really surprised if it was the tire. I am running the same tires on my 22" intros with no issue at all.
With the money we spend on these aftermarket parts you think their main priority would be quality control, especially as a small business.
Brandon Instagram: DRVFSTR Current Project: Beatrix - 1967 SWB LQ4/78mm Turbo/4L80e/ on bags Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=634691 |
#356 | |
#357 |
///Relaxed Atmosphere
that sucks brother id be pissed also... maybe like mentioned send the wheels and tires to billet specialties and have them mount them for you especially since this is the second time. that's a lot of money for it to be wrong twice
71-Cheyenne Super (E.C.E Static Drop 4.5/7". Intro Rally's 20X8.5 5" B.S 255/35/20 (F) 20X10 5.25 B.S 275/35/20 (R) 87-Silverado Static Drop 5/7" Raceline Explosion 5 22X8.5 (F) 22X10 (R) hector _________________________________ 1971 Chevrolet Cheyenne Super 1987 Chevrolet Silverado 2006 Ford Mustang GT 2012 Toyota 4-Runner 2014 Dodge Ram 1500 Sport Crew Cab |
#358 |
I would rather have them fixed and know I could mount the tires then take a chance of them cramming them on, messing them up, then getting stuck somewhere with a flat I cant fix. I'm with Keith on this one, I would be done with them as a company and find another one to do business with!
#359 |
I'm just glad to be here!
I had a very similar problem with a set of 10" wide 20" Eagle 225's. The tire shop had to mount them from the back side, and soap the crap out of the barrel and the tire. Once the tire was on the rim, it went into a safety cage to get the bead to seat. It took more than the normal pressure to seat them and when they did the WHOLE shop new it....
Karl ![]() 1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues) http://67-72chevytrucks.com/vboard/s...d.php?t=372424 The LST Challenge: http://67-72chevytrucks.com/vboard/s...=1#post7812257 Korbin's 1st Square: "Sunburn" http://67-72chevytrucks.com/vboard/s...d.php?t=418618 1985 GMC Sierra: "White Trash", Korbin's 2nd now... http://67-72chevytrucks.com/vboard/s...d.php?t=632305 Henry - 1984 Chevrolet, Owen's 1st Square |
#360 |
I would not send the wheels/tires back to let BS mount them. What about future replacement or repairs? If quality, local places can't mount the tires, the wheels need to be fixed (replaced}.
To me, the barrel itself looks odd. The tire gets stretched to slip over the lip of the barrel but then the barrel doesn't drop down much @ all in diameter toward the center.
#361 |
Great point about future repairs, but the alternatives are to either get new wheels or continue the back and forth with BS. If BS is willing to accept the wheels/tires and certify (in writing) that any local place can mount tires all should be well with the world.
If they won't....thank them for their time, write a detailed review online and get some new wheels.
69 C10 SWB -- Left to me by a loving father. Finishing the build we never got the chance to do together |
#362 |
Update on the wheels, after some back and forth, the wheels are going back to Newstalgia Wheel. Billet Specialties wants me to send both the wheels and the tires to Newstalgia Wheel to see if they can mount them. I said no to that! They can have these junk wheels back and try to mount tires of the same diameter on them.
SCOTI and Brandon are right, I want to know that if needed, I can mount new tires on these wheels without any issue. I can't be sending my wheels to them every time I need new tires. I also told them that the only way I would take these wheels back is if they re hooped them with new barrels. I don't feel comfortable riding around on wheels that possibly the integrity of the wheel has been compromised because they keep cutting on the barrel. I stated that I want my money back and of course they are dancing around that saying they just want to make sure I have wheels for my truck and that I'm happy ![]() ![]() ![]()
Keith 66 Suburban Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361 IG: bennett68c10 Last edited by Bennett68C10; 08-02-2016 at 10:52 AM. |
#363 |
I really love those Heritage G wheels. But I agree, I would be fed up at this point. This may be dumb, but wouldn't a simple diameter measurement tell them if it was the wheel, or the tire that is the problem?? Anyway, keep your head up, it will work out. Your truck is going to be amazing with any wheel.
1970 SWB Build Last edited by jmking9; 08-02-2016 at 04:56 PM. |
#364 | |
#365 |
I've been so wrapped up with the wheels that I haven't updated that I got the motor mount issue resolved on the Choppin Block front kit. Travis at AZProPerformance was on top of things and had new motor mounts and inner frame stiffeners to me within 2 days! This corrected the angle of the engine so now I sit at exactly 5 degrees down. The customer service Travis supplies is amazing, he even reached out to me and tried to assist me with my wheel problem, giving me some advice on what he has seen on some of these wheels! I really appreciated that especially since I didn't even purchase the wheels from him!
#366 |
![]() Join Date: Feb 2010
Agreed Travis and his crew at Pro Performance are pretty impeccable. Nice looking build you have here, I have been following along.
My Build Thread Here http://67-72chevytrucks.com/vboard/s...d.php?t=457417 |
#367 | |
Still Learning
The suspension looks great! Keep your head up, you don't "need" the wheels until you're ready to cruise anyway.....You know you'll change your mind about them before you're ready to drive it.... ![]() Get some rollers and press on. |
#368 | |
Jason '70 C-10 short fleet 427BB TH400 (SOLD) '10 Ford F 350 '13 Ford RAPTOR 6.2 MY BUILD THREAD http://www.67-72chevytrucks.com/vboa...d.php?t=612623 |
#369 |
I agree that's Bul*****t. They have to make it right.
The guy that installed my tires took about 1.5 hrs and they sat for 2 yrs. When I was ready to install I had changed my mind on the style but your style of wheel will always be good.
Rincon |
#370 |
Well guys I received a full refund back yesterday from Billet Specialties and Newstalgia Wheel. Newstalgia wheel could only get a tire on one of the 4 wheels. They took measurements of the barrels and they were still way to large to ever get a tire on. Billet Specialties wanted me to let them rehoop the wheels with new barrels but I said no, I wanted my money back. I told them that they should have rehooped the wheels the first time they went back to be "fixed". Instead they took the easy way out and sent me wheels for a second time that I couldn't do anything with.
So I'm done with Billet Specialties and maybe billets in general after reading about the problems others are having with the 22" hoops on Intros, Racelines and Schott. I could go back down to 20's, but then I would have to sell my tires too ![]() I will say this, Newstalgia wheel is a stand up company as they worked hard to resolve the issue and dealt with me for a month not exactly being the nicest person. I wouldn't hesitate ordering from them in the future.
#371 |
![]() Join Date: Dec 2012
That's disheartening man but don't let it kill your motivation. The truck is going to be bad ass when your done!
__________________ Mike 70 Med Olive build http://67-72chevytrucks.com/vboard/s...d.php?t=714804 Instagram- protouring66 |
#372 | |
Todd https://www.instagram.com/shores6/ Project: Boosted Blucille. '70 C10 SWB PB Fab, LS2 S480 - http://67-72chevytrucks.com/vboard/s...d.php?t=700419 |
#373 |
Keith this must be something recent with the barrel supplier. I had no issues at all with my 22 inch Intros. Maybe its because I got them through Travis though
#374 | |||
#375 |
Junior Member
My wheels should be here next week & I'll have the tires mounted asap. I'll report back to let you know if the problem has been resolved!
