Old 08-03-2016, 08:30 PM   #1
Someday
Someday's Avatar
Seat belt bolt
I have a 1971 SWB Fleetside with bench seat. It has the original driver and passenger retractable 2 point seat belts. I ordered an original looking lap belt for the middle seat of the bench from Brother's truck parts.
My question... Can I use the stock bolt to add the lap belt or do I need one with a longer 'shoulder'? If I need a longer one, does anyone know where I can find one?
Thank you for the help!!!
Someday is offline   Reply With Quote
Old 08-03-2016, 09:36 PM   #2
In The Ten Ring
Re: Seat belt bolt
I put my bench seat back in last summer (with middle belt) and I think you'll be OK with what came in the truck........
If nothing else, "ttt"
In The Ten Ring is offline   Reply With Quote
Old 08-03-2016, 09:53 PM   #3
Someday
Someday's Avatar
Re: Seat belt bolt
Thank you, did your truck originally come with a middle belt?
Old 08-04-2016, 10:39 AM   #4
In The Ten Ring
Re: Seat belt bolt
Yes it did. Now dad could have put that in there, but he never said anything about it.
The bolt's weren't that long as I recall....I suspect you will be OK. If not, you should be able to get a working substitute bolt pretty easily. I think the bolts were grade 5.
Old 08-04-2016, 04:18 PM   #5
'68OrangeSunshine
'68OrangeSunshine's Avatar
Re: Seat belt bolt
My '68 C/10 Stepside came with OEM middle seatbelt. They share the inboard mounting bolts from the Passenger and Driver's belts.
Old 08-04-2016, 06:22 PM   #6
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Re: Seat belt bolt
Same as my '72 K20. The only reason I'm sure is that I just replaced the OEM belts with new 3-points (with center lap belt).
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Stocker is online now   Reply With Quote
Old 08-04-2016, 07:29 PM   #7
Someday
Someday's Avatar
Re: Seat belt bolt
Thanks for the help guys! I understand to use the same mounting location. My question is more is it a different bolt (longer, longer shoulder?) when using a center lap belt. I was just wondering if my OEM bolt used for just driver/passenger seat belts going to be long enough to use with driver/center/passenger seat belts. Thanks again!
Old 08-04-2016, 07:35 PM   #8
Grumpy old man
Grumpy old man's Avatar
Re: Seat belt bolt
ok , the outside uses a short bolt anytime you have 2 belts bolted to the same location they use a longer shoulder bolt . cars/ trucks/ go carts / etc,etc
Old 08-05-2016, 08:37 PM   #9
'68OrangeSunshine
Re: Seat belt bolt
You can try the double belt ends in one bolt first. Doesn't make sense for the manufacturer to have 2 different size bolts on the production line. But I'm guessing here.
