08-04-2016, 01:42 PM | #1 |
Draw-through turbocharging
Does anyone have some good resources in regards to a draw-through turbo setup? I'd like to keep the modifications era-correct. It's well down the pipeline for my project...it's a stock (for now) 292
1967 C20 - "Ye Olde Farme Trucke" - 292, SM420...manual Powerglide with double low |
08-04-2016, 04:08 PM | #2 | |
Re: Draw-through turbocharging
Look up posts by a guy named Tom Lowe [T. Lowe]. He seems to be a leading proponent of this technology. www.inliners.org
08-05-2016, 10:22 AM | #3 |
Draw through may have been more prevalent for the era but there were blow through turbo setups as well, although most of those were injected. I'd seriously consider blow through for better drivability and less hassle. You can always make it look more vintage with the right carb, carb hat or box, tubing, etc.
08-05-2016, 01:08 PM | #4 |
Draw through is like an assembly line that is constantly assembling a bomb, and just waiting for a match! Sometimes it seems like a simpler option, but be ready for the backfire....
1970 GMC Sierra Grande Custom Camper - Built, not Bought 1969 Pontiac 2+2 427/390 4-speed Coupe 1969 Pontiac 2+2 427/390 4-speed Convertible |
08-05-2016, 08:57 PM | #5 | |
As I said before there were blow through setups in that era. In fact there were some with intercoolers as well. I can't find pics of it but a Turbonetics built 65ish twin turbo Hemi car with twin water to air intercoolers in the fenders. There was a Willy's drag car with a twin turbo small block with modified vette fuel injection built in the 60's too. Both in Hot Rod at one point. Point is there was plenty of experimentation going on back then with lots of different combos not just draw through. Not like today where everyone is building a LS with a single 78mm hanging off the right side. If it was me, I'd build it to look vintage. Turbo with an as cast look, unpolished compressor housing, vintage carb and a carb hat that's not streamlined like today's versions. Maybe a diesel turbo, they tend to look older and paint the compressor housing the same color as the engine, that'll help the look. Idk exactly what I'd do for the piping. If you're not going for big power then maybe no intercooler but definitely keep the pipe couplers to a minimum and no v-band clamps for a vintage look. Just some ideas to consider. |
