#201 |
Re: The Old Mule - 64 BBW
To me it sounds like a problem with the booster itself since a vaccum leak likely wouldn't go away temporarily. But check for leaks just in case, on my dads car we were going down the road one time and the vacuum hose popped right off and we lost power brakes completely
Nik...................____ 62 lwb c10 step-side 261 5 spd .........________//__{\_____ ,,,,,,,/__(O)___//___/__(O)_/ my build thread. Sending unit solution |
#202 |
The booster went bad in my Jeep it acts the same as yours some days good other it is like I have manual brakes, it's on my list. No vacuum leaks, I believe it's a internal valve.
http://67-72chevytrucks.com/vboard/s...d.php?t=648459 https://67-72chevytrucks.com/vboard/...d.php?t=769441 1951 MG TD 1967 Jeep CJ5 1.9L TDI 33X13.5X15 Mud Grapplers. 1952 GMC 9700 p/u 7.3L diesel on air, dually |
#203 |
![]() ![]() Join Date: Jul 2002
Got some time between yard work and kitchen redo to work on the Mule. Since the power brake booster decided to die, I figured I would replace it. Got the part in yesterday and got her out, then I discovered my custom setup. Coupling bolt welded on to the booster rod. So that was short lived. Going out to try and find the adjusting pushrod that is correct for the vehicle since I could not find one in my stash.
#204 |
Could not find any rods locally, but found one on ebay. So now it is like the military, hurry-up and wait.
Oh well, the AC feels real good about now anyways. Shop got pretty warm today.
#205 |
How did the rear sway bar work on your truck? Or have you been too busy too install it?
Kerry My build thread. http://67-72chevytrucks.com/vboard/s....php?p=3657823 1971 Chev SWB with 68 nose, 6.2 diesel th350, and 3.73 rear gears 1988 Chev Extendacab 2010 Honda VT1300CS Sabre 2005 Buick Rendezvous wife's ride |
#206 |
Like a few other things I am still "fixin to" get in on the truck. After I get the brakes back to functioning, that is on the list.
#207 |
I know what you mean, I still have the front one to put on.
#208 |
After getting the yard done, decided to tackle the brake. Luckily it went fairly easy. I had to modify the universal push rod so it would be short enough, but all is good now. The Mule be mobile (and stops) again!
Hopefully will get to the rear sway bar next weekend
#209 |
If we didn't have to modify almost every part, it wouldn't be called building a truck. It would be assembling.
#210 |
Stopping is always good. Glad it went smoooooth.
#211 |
It's good to be home, but I sure wish the temps were like up north in PA. Dang it is HOT/HUMMID down here in ole Mississippi.
My wife and I have been on Holiday as some folks say. Went to visit family and spend some time in the Pennsylvania mountains north of my homeland of Pittsburgh. No cell phone coverage, had to text thru a wi-fi connection to make sure the son didn't burn down the house while we were gone. Love the mountains and the tranquility. It's a place called Cook Forest in north central Pennsylvania After mowing the yards this morning, I continued to bake and sweat profusely as I serviced both mowers. I then decided to take the Mule for some cruising time, as well as run some errands. Oh it felt so good to drive it again. Brakes work better than before, so I guess the booster fix works. Hopefully our kitchen remodel will be done this week, then I can get back on truck stuff more, even if it is like working on the surface of a skillet.
Bill 1970 Chevy Custom/10 LWB Fleetside 2010 Toyota Tacoma PreRunner SR5 Double Cab - DD Member of Louisiana Classic Truck Club (LCTC) Bill's Gallery Life isn't tied with a bow, but it's still a gift. Live simply. Love generously. Care deeply. Speak kindly. Leave the rest to God! Last edited by Palf70Step; 07-10-2016 at 01:27 PM. |
#212 |
Who would call a vacation a Holiday ??
Nice one though Bill. Even better of course is having Mrs Boss with you.
MY BUILD LINK: http://67-72chevytrucks.com/vboard/s...585901]Redneck Express - 1966 C10 Short Fleetside MY USA ROADTRIPS http://forum.retro-rides.org/thread/...2018-humdinger IF YOU CAN'T FIX IT WITH A HAMMER, YOU'VE GOT AN ELECTRICAL PROBLEM MATE. |
#213 |
Looks great, like home to me, the great Pacific North West. (except the skillet heat).
Nice shot of the Mule and the both of you together. Enjoy your Holiday |
#214 |
Not a lot of anything being done, except driving. Which is always a good thing. Since the vacation, the Mule has been my DD because the engine gave out in my 02 Silverado. It is a joy to drive the ole dude, except when you get stuck in traffic and 95+ degree weather (and 900000% humidity).
I did have to change out the headlight switch. The reostat portion failed and I losdt all dash lights. I grabbed a new part. At first I thought hmmmm different part# than couple years ago, but it is different brand...so the thought left my head. AS I went to put it on I noticed an extra post, but then again I ignored it. Everything worked fine after I connected it. Turns out they gave me the switch# for a 74 not a 64 C10. Anyways it works, near as I can figure the extra post has something to do with making the the front park lights stay on with teh headlights. Anyhow, just to let you know, it works just in case you are ever in a tight spot. By the way the comment about heat and traffic was due to our little cruise to Baton Rogue yesterday to meet with some truck folks for breakfast. About 280-300 mile cruise to get breakfast. ![]() Here is a few pics of the trucks that were there
#215 |
Nice looking truck lineup. I gotta hand it to you...I may be getting soft, but I don't know how you do it without a/c. I use a track loader (with a/c) and a tractor (without) for my business. The older I get the more excuses I make for taking the track loader to work every day.
Romans 10:9 - The Truth |
#216 |
Ya 280-300mi is just around the corner right? The line up looks real nice. Did you all cruise there together or meet there?
#217 |
Your truck is looking good Bill! Sure looks like a blast crusin with the buds eh!
#218 |
WE just met there we cover about a 300 mile range the southern district of the club.
#219 |
Nothing this weekend except the Mule is still the daily driver. Like many have mentioned elsewhere this weekend was yard and non-truck things. Serviced and mounted new tires on the lawn tractor (pain in my butt).
I love driving the 64 everyday, but it would be nice to have a version of AC that doesn't require me breaking the sound barrier (and many posted rectangular white signs). I'll be glad when the fiasco with Whitey is down. I love this 64, but in south Mississippi in July-September, AC might push the 64 to the #2 love position. ![]()
#220 |
Felt your pain with the brake booster.I had a minor steering issue.vThese are all little bump's in the road.
The Snortin' Bull |
#221 |
I was just reading that, is yours the original style power steering or a later model added on?
#222 |
I just realized you work right down the road from me!
Gary 1971 Chevrolet C/10 1951 GMC 100 1977 GMC C15 1955 Chevrolet 3100 |
#223 |
Kool. We'll have to hook up some day
#224 |
Well, the Mule will get to rest a few days. Finally got my son's truck back together. Only took 3 tries on finding a good motor. Nothing special, but a good solid 4.3 in it again. The Mule hasn't seen the inside of his house in a while, so it is time for a few days rest, just in time also. I didn't want to keep driving it in the weather. It makes me nervous driving and you can hear the tailpipes gurgle because the are touching water.
Good part is I have a truck to drive with AC now if I want to...........and I DO! ![]()
#225 | |
But Found Her 25yrs Later!
![]() Join Date: Oct 2010
