Old 08-11-2016, 02:50 PM   #1
RANDY COX
RANDY COX's Avatar
which frame
As titled I'm wondering which frame I have, was told it was early 70's frame this is 4x4 btw,my truck when I bought it was a 64 sitting on an early 70's, But I need to know exactly which yr as I'm considering a lift and don't want to order the wrong one, I saw some #'s on the right front toward the spring hanger mount the last # was 70, so can I assume that it's a 70 or do I need to measure the spring width or length of springs, any help would be greatly appreciated...this is a Frankenstein truck...LOL......................
1964 BBC 402 4x4
RANDY COX is offline   Reply With Quote
Old 08-11-2016, 04:31 PM   #2
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Re: which frame
Can you post some pictures so we can try to help you? How about some leaf spring measurements? The 72 and down have shorter front springs than the 73 ups. The pre 72 frames are also narrower than the 73 up frames.
Ryan
1969 Chevy milk truck
Old 08-11-2016, 10:29 PM   #3
RANDY COX
RANDY COX's Avatar
Re: which frame
hope this helps...the front end partially disassembled...
when I first got the truck someone had cut straight into the frame horns and split them don't know they did that but I cut them off so I could use the 64 frame horn to mount my bumper...I'm trying to think how they looked when I cut them off...anywho I still believe it's 70-72 frame...the truck does have disk brakes so I know they didn't have them until 71-72...
1964 BBC 402 4x4
Old 08-12-2016, 03:20 AM   #4
RedRoad
RedRoad's Avatar
Re: which frame
The strap on the front of the driver side leaf makes me think it is a 72 and earlier frame. Is there a Vin number stamped into the frame near the steering box?
RedRoad is offline   Reply With Quote
Old 08-12-2016, 07:41 AM   #5
74CustomK20
74CustomK20's Avatar
Re: which frame
I agree 72 and earlier, but to double check just measure the mounting holes and call where you wana order from.
Big Nate
Carp. Local 224. Buy made in the USA!
03 F350 6.0 Daily Race Truck.
79 C70 366 Project Dump.
74CustomK20 is offline   Reply With Quote
Old 08-12-2016, 07:27 PM   #6
RANDY COX
RANDY COX's Avatar
Re: which frame
Yea that a good indicater with the strap across the left front spring hanger...I should've noticed that myself...
1964 BBC 402 4x4
Old 08-12-2016, 08:04 PM   #7
jjzepplin
jjzepplin's Avatar
Re: which frame
72 bump stops were bolted in like yours. My 1970 bump stops were held in by the rubber. However the sway bar appears to be of 73 or newer type with mods to make it work. Need pics of the whole truck though! Just because we like pics!
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller
72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build
Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350
jjzepplin is online now   Reply With Quote
Old 08-12-2016, 08:55 PM   #8
RANDY COX
RANDY COX's Avatar
Re: which frame
Yea the sway bar was added by the P.O. and pretty sure my bump stops are bolted on...I know when you order the lifts that there always from 69-72 so I should be safe with that...Boy I had my hands full or should I say truck full my son got a project truck an
82K20 and I hauled it home yesterday...
1964 BBC 402 4x4
Old 08-13-2016, 02:58 AM   #9
andrewmp6
Re: which frame
Would there be a vin on the frame with it being that old ?
Old 08-13-2016, 09:03 AM   #10
RANDY COX
RANDY COX's Avatar
Re: which frame
Oh I should have said that the 64 body is on an 4x4 chassis this is a Frankenstein truck..I recently went from a 292 six to a 402 BBC...
1964 BBC 402 4x4
Old 08-15-2016, 03:39 PM   #11
Dieselwrencher
Re: which frame
Very nice engine swap! I'm pretty certain that only 1972's had that strap on the front hangers. (I could be wrong though)
Ryan
Old 08-15-2016, 04:27 PM   #12
RedRoad
RedRoad's Avatar
Re: which frame
My 65 C10 has the vin stamp in the frame, in fact I think I see it in this pic.
Dont think GMCs had frame vins on early trucks though
Old 08-19-2016, 08:35 PM   #13
RANDY COX
RANDY COX's Avatar
Re: which frame
I'll have to check that area I haven't really noticed...
1964 BBC 402 4x4
Old 08-24-2016, 11:30 PM   #14
'63GENIII
'63GENIII's Avatar
Re: which frame
Hey Randy, I really like the painted front frame and firewall. What did you use to paint with? Rattle can or spray gun? Im at that point with the '63 and am not really ready to bite the bullet on a spray set up.
Chris
'63 k15 long step
Vortec 7.4 - L29 Blackbear tune, Five 0 Motorsports injectors, Chris Straub Cam, NV4500, divorced 205
52" front and 63" rear spring swap
D44 / 14bff - disc axles
Milemarker 9K and 10.5K hydraulic winches
63" & B52 Spring Install http://67-72chevytrucks.com/vboard/s...ng+swap+thread
NV4500 Reverse Build Thread http://67-72chevytrucks.com/vboard/s...=reverse+build
L29 - 7.4 Vortec Build http://67-72chevytrucks.com/vboard/s...&highlight=L29
'63GENIII is offline   Reply With Quote
Old 08-26-2016, 08:52 PM   #15
RANDY COX
RANDY COX's Avatar
Re: which frame
Hey everything was rattle can I sanded everything down and primered with rattle can too..
1964 BBC 402 4x4
Old 09-03-2016, 12:20 PM   #16
'63GENIII
'63GENIII's Avatar
Re: which frame
Man that turned out nice. Ive been debating rattle can engine paint vs rattle can automotive paint (that I can get at my local Napa) for a while. You may have just helped me make my decision.
Chris
'63 k15 long step
Old 09-05-2016, 09:39 AM   #17
bhc41051
bhc41051's Avatar
Re: which frame
Randy if you have a 72 short wheelbase frame, this would be the direction I'd be heading.
bhc41051 is offline   Reply With Quote
Old 09-05-2016, 10:02 PM   #18
RANDY COX
RANDY COX's Avatar
Re: which frame
I hear ya there, I had a 4x4 suburban of that era, I wanted a 60's 4x4 and that's when I found this truck..
1964 BBC 402 4x4
Old 09-08-2016, 09:01 PM   #19
Mudder
Mudder's Avatar
Re: which frame
73 and newer frames the rear shocks are on opposite sides of the rear axle.
Mudder is offline   Reply With Quote
Old 09-11-2016, 03:46 PM   #20
RANDY COX
RANDY COX's Avatar
Re: which frame
Oh ok Mudder, I'm pretty sure that there both are mounted on the same side...
1964 BBC 402 4x4
Old 09-11-2016, 08:27 PM   #21
57taskforce
All about them K’s
57taskforce's Avatar
Re: which frame
Looks like a 72 frame to me. definietly looks like a 67-72 frame, the front frame horns that are still attached to the bumper look like 67-72 horns.as said before with the spring stops and open knuckle disk breaks I'd say 72.
Tyler
