Old 08-12-2016, 11:25 AM   #1
SilverMiner
SilverMiner's Avatar
What is this on my floor pan?
I'm tearing out the interior of my 1980 K10 Silverado Suburban. Once I got the carpet and vinyl backed jute out I was surprised to learn I still wasn't down to metal floor pan. Instead I found what you see in the attached photo. The photo is looking at the drivers side floor pan with the front curve of the door seal visible in the lower left.
The floor appears to be covered entirely with this moderately stiff vinyl material. Based upon the primer found underneath and the body color on top, it appears to have been glued on at the factory. I've owned quite a few of these rigs and have never encountered this vinyl floor covering before, but this is my first 1980 model.
I plan to remove all of it even though it seems to be an important part of GM's sound deadening scheme. It seems to be stretched over the top of some low spots in the pan and I'm concerned it can trap water and promote rust.
After finding this, I'm wondering now how much improvement I'll see installing the my new sound deadening material versus what GM provided.
1980 K10 Suburban Silverado, original 350 w/Qjet swapped to 406sb, TH350C swapped to TH400/205
SilverMiner is offline   Reply With Quote
Old 08-12-2016, 07:58 PM   #2
Gmc.guy
Gmc.guy's Avatar
Re: What is this on my floor pan?
Was it a diesel at one time. I've seen some weird stuff on those. My 84 6.2 has the same type of thing on the outside of the firewall, same moulded type insulation. Covers the a/c set up and stuff
-Cody
Gmc.guy is offline   Reply With Quote
Old 08-12-2016, 09:14 PM   #3
SilverMiner
Nope, never a diesel. A regular old 350/TH350C/NP205 combo that they made millions of. I bought a copy of the build sheet from the GM Heritage Archives and everything checked out original except the gear ratio.
You are right though about the diesels getting the super soundproofing treatment. I had forgotten about that and will use it to search for more info.
Old 08-12-2016, 11:27 PM   #4
69heavychevy
69heavychevy's Avatar
Mine trucks has the same thing, but its only on the drivers side. Its also an 80 model.
80 C10 SWB Step Side - 350 w/ vortec heads, TH350, 12-bolt 3.73
69heavychevy is offline   Reply With Quote
Old 08-13-2016, 01:21 AM   #5
finewayne
had that too, any suggestion yet?
finewayne is offline   Reply With Quote
Old 08-13-2016, 09:58 AM   #6
Matt Man
Matt Man's Avatar
My 81 scottsdale had this covering as well, I took it off though because I see it as a moisture trap for rust. My truck is also a 350/th350c/208 ect...
86 c30 crew cab dually 454/400 4/6 drop SOLD 1-8-11
1981 chevy K10 short Bed Scottsdale SOLD 10-26-2020
67 GMC Stepside Straight six/3 on the tree "The Peach"
2020 Silverado Double Cab LT Z71 5.3 8 speed Daily Driver
K10 build http://67-72chevytrucks.com/vboard/s...d.php?t=671934
The Peach build http://67-72chevytrucks.com/vboard/s...d.php?t=733903
Matt Man is offline   Reply With Quote
