Old 08-13-2016, 01:57 PM   #1
72bowtiestepper
72 C-10 throttle cable
Does anyone have the correct throttle cable length for a 72 c-10 with a 350 using a Holley 600 cfm (4160) carb.? My engine is in the rearward set of mounting holes (the 4wd position). Parts catalogs I have seen list 2 lengths of stock cables for 71-72 but don't list the lengths of the cables, one for 2wd & another for 4wd.,which I assume is shorter. The cable I have now is 21" from end to end, & is way too long for my application. I know aftermarket cable set ups are avail. from Lokar & others, but I would like to use a stock cable if possible.
Anyone have a measurement for the 4wd cable ??
72bowtiestepper is offline   Reply With Quote
Old 08-14-2016, 10:47 AM   #2
72bowtiestepper
Re: 72 C-10 throttle cable
Bump....anyone have a 4wd cable they can measure ???
Old 08-14-2016, 04:43 PM   #3
Custom/20
Custom/20's Avatar
Looks like you have the cable for the 2WD setup. The 4WD should be 18 inches.
2WD Cable: http://www.classicparts.com/mobile/1.../#.V7DW9mllDqA
4WD Cable: http://www.classicparts.com/mobile/1.../#.V7DW82llDqA
Custom/20 is offline   Reply With Quote
Old 08-14-2016, 04:45 PM   #4
72bowtiestepper
Thanks for that info. Custom/20 !!
