Old 08-18-2016, 12:37 AM   #1
red450ih
red450ih's Avatar
1969 C-20 396 Intake Casting Number
I have searched online to no avail for the intake manifold casting number that would have been on a 1969 C-20 396. All I have found so far are casting numbers for cars of similar vintage. Can someone point me in the right direction? Thanks!
GMC
red450ih is offline   Reply With Quote
Old 08-18-2016, 12:11 PM   #2
GRX
GRX's Avatar
Re: 1969 C-20 396 Intake Casting Number
Only one casting that year. #3933163 ... a 396 intake is a 396 intake.
1969 c-10 Step Side Long Bed. I-6 250cid = = 1969 Pontiac GTO hard top. 400, 4-speed.
GRX is offline   Reply With Quote
Old 08-18-2016, 04:37 PM   #3
red450ih
red450ih's Avatar
That casting is not a truck Q-jet cast iron manifold
GMC
Old 08-18-2016, 05:01 PM   #4
davepl
davepl's Avatar
My best guess is 3866961 for 66-69 396 truck.
That's the -only- number I can find that says 396 truck without being raised deck (366,427).
https://www.rapidomarine.com/default..._castings.aspx
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 08-18-2016, 07:11 PM   #5
Custom/20
Custom/20's Avatar
My 69 C/20 with a 350 came with a 68 drivers side exhaust manifold. So it is possible that you could have a older big block intake.
Casting numbers. http://outintheshop.com/faq/casting/castings2.html
Custom/20 is offline   Reply With Quote
Old 08-18-2016, 08:34 PM   #6
jr1000yarder
3883948 if your truck block is a 68 block and not a later 69 block
IT IS WHAT IT IS
jr1000yarder is offline   Reply With Quote
Old 08-18-2016, 08:39 PM   #7
jr1000yarder
Correct
IT IS WHAT IT IS
Old 08-18-2016, 09:07 PM   #8
ghalperin
ghalperin's Avatar
My 1969 C30 Longhorn 396 motor has 3931067. I was told it's stock and original, but it translates to 325 L-35.
Glenn
1960 Burro Corvair/VW Buggy - Factory made in Santa Ana, Ca
1929 Ford Model A Roadster - traditional pre-war banger hot rod
ghalperin is offline   Reply With Quote
Old 08-18-2016, 09:32 PM   #9
jr1000yarder
You have a picture of your carb springs on that set up?
IT IS WHAT IT IS
Old 08-18-2016, 10:07 PM   #10
ghalperin
ghalperin's Avatar
Glenn
Old 08-18-2016, 10:11 PM   #11
Eagle9502
According to my book ("Car & Parts Catalog of Chevy V-8 Engine Casting Numbers 1955-93"), 3931067 is a '69 396 car and light truck cast iron oval port with Q-jet. I have found 3883948 to be '68 car and light truck cast iron oval port with Q-jet. Both of these are high rise intakes.
Eagle9502 is offline   Reply With Quote
Old 08-18-2016, 10:23 PM   #12
jr1000yarder
That sounds right Eagle
IT IS WHAT IT IS
Old 08-18-2016, 10:25 PM   #13
jr1000yarder
Ghalperin, what spring is on the front of the carb. I believe mine to be incorrect. ...
IT IS WHAT IT IS
Old 08-20-2016, 12:57 PM   #14
red450ih
red450ih's Avatar
Thanks for the replies. I'll probably just get a 3931067 intake. For some reason I was thinking the truck intake was different for some reason.
GMC
Old 08-20-2016, 01:09 PM   #15
davepl
davepl's Avatar
It's different than the 325hp car intake, is it not? The 3866961 casting, so far as I know, is the extra-low-rise intake (like we need the hood clearance). I don't think it's the same as the car unit, but I'm no expert.
I can get you the number right off my factory 1970 unit, but that's newer than you want, I think.
Old 08-20-2016, 01:29 PM   #16
ghalperin
ghalperin's Avatar
I wish that I could help, but mine is MIA.
Glenn
Old 08-20-2016, 06:01 PM   #17
Dirt's72
My 69 custom camper 20 with the original 396 is 3931067.
Dirt's72 is offline   Reply With Quote
