Old 08-21-2016, 04:28 PM   #1
In The Ten Ring
6 cylinder radiator question.
Definitely redundant but it's a slow day. I have the 250 6 cylinder and I want a new radiator (old one has some leaks).
Any negatives to going with a 3 or 4 row radiator? Will I have to change thermostats or water pump?
In The Ten Ring is offline   Reply With Quote
Old 08-21-2016, 06:00 PM   #2
GRX
GRX's Avatar
Re: 6 cylinder radiator question.
No negatives at all. Same stat & pump.
Did just that to my 250 powered c10 about a year ago. Switched bad stock radiator to a 3-row. Was out of a 69 GTO actually. Only minor differences. One thing I like about GM. Many parts interchange.
1969 c-10 Step Side Long Bed. I-6 250cid = = 1969 Pontiac GTO hard top. 400, 4-speed.
GRX is offline   Reply With Quote
Old 08-21-2016, 06:02 PM   #3
In The Ten Ring
Well that is good news, thanks. Now to get a radiator that isn't made of plastic.
Old 08-21-2016, 06:53 PM   #4
firedemon
I used an 8 cyl radiator only thing had to change was lower hose top is the same the lower needed to be 4 inches longer because of it being a wider radiator
firedemon is offline   Reply With Quote
Old 08-22-2016, 01:05 AM   #5
'68OrangeSunshine
'68OrangeSunshine's Avatar
If you're installing V8 radiator, you will have to move the passenger side upper and lower radiator support brackets out further.
'68OrangeSunshine is online now   Reply With Quote
Old 08-22-2016, 01:24 AM   #6
In The Ten Ring
That's a good point, thanks. I should be OK as I am replacing my radiator core support with one from a 396 cu. inch engined truck. My core support was badly rusted.
