08-22-2016, 12:02 AM | #1 |
Fuel sending unit?
I bought a brand new 21 gallon fuel tank and matching sending unit for my 69 blazer from brothers truck parts and I have a new cluster from lmc. The issue I am having is I can fill the tank full of fuel and the gauge will read exactly full and it will go down just fine but when the fuel gauge is showing empty it will only hold about 14 gallons to fill it back up so something is not correct. Has anyone had this issue or does anyone know what could possibly be wrong?
08-22-2016, 05:26 AM | #2 |
Re: Fuel sending unit?
Maybe the gadge itself has a defect
1970 Jimmy 4x4 IL6 1971 Jimmy 4x4 350ci v8 1971 SWB 327ci v8 1972 Short Stepside 305ci v8 1972 Blazer 2WD CST LS9 350ci 4sp 1999 4 Door LB 1 Ton Old Body Style 5.7 v8 |
08-22-2016, 09:01 AM | #3 |
maybe they sold you a 14 gallon tank. what are the dimensions on your tank
08-22-2016, 09:36 AM | #4 |
2WD Jimmy
You might want to post this question in the electrical forum as well.
08-22-2016, 10:43 AM | #5 |
If you unplug the sensor does it go beyond full? If you short that wire to ground does it go below E? But if I had to guess, I'd say the resistance of the imported sending unit is not quite the same as the factory unit.
08-22-2016, 05:52 PM | #6 |
My tank dimensions are 26x16x13 which comes out to be 22 gallons when you figure up the dimensions so it is a 21 gallon tank so something has to be wrong with the sending unit or the gauge itself. I was just trying to see if anyone else has had this same issue with there new sending unit or cluster before I tore into it deeper to try to figure out the problem.
08-23-2016, 09:41 AM | #7 |
To me, it sounds like the sender has the wrong resistance value for that particular gauge. I would check the actual resistances from the fuel sender when empty and full with an ohm meter, then check the part number of the gauge to see if it's compatible.
