Old 08-22-2016, 04:06 PM   #1
71threequarterton
71threequarterton's Avatar
Sticky Brake?
The previous owner mentioned this before I bought the truck and I have now experienced it for myself: The driver side rear brake occasionally locks up. I think it's happened about 3 or 4 times now when coming to a stop at a stop sign or traffic signal. Does anybody have an idea what would cause this?
-Jim
71 Chevrolet C20
94 GMC Yukon 4x4
71threequarterton is offline   Reply With Quote
Old 08-22-2016, 04:10 PM   #2
Wrenchbender Ret
Re: Sticky Brake?
You probably have grease or brake fluid leaking & getting on the linings. Or it may be an emergency brake cable sticking or adjusted up too tight.
Wrenchbender Ret is offline   Reply With Quote
Old 08-22-2016, 04:24 PM   #3
cleszkie
cleszkie's Avatar
Re: Sticky Brake?
The brake shoes with long and short lining might be reversed. They need to be installed in a particular way, or the shoes can have a tendency to bind with the drum and not fully release.
cleszkie is offline   Reply With Quote
Old 08-22-2016, 10:18 PM   #4
firedemon
Re: Sticky Brake?
wheel cyl could be starting to rust inside and sticking sometimes most people don't change fluid all that often and brake fluid sucks in moisture . its relatively cheap to do rear brakes id replace everything .
firedemon is offline   Reply With Quote
