![]() Join Date: Jun 2015
Frame to Cab measurements
Hi all,
Currently my Frame and Cab are separated like divorcing parents. Can anyone help me out with some Frame to Cab floor measurements? Hopefully from a truck with NEW body bushings? This would be in the area of the transmission cross member and need to be from the top of the Frame Rail to the bottom of the Cab Floor. I am starting to run my new fuel lines and need to know if there is enough room between the Catalytic Converter shield and the floor. Thanks, Jay
Jay Gesner Atlanta, GA 1985 C10 Long Bed 4X2 LS 5.3, 4L60E Father/Daughter Project |
Re: Frame to Cab measurements
Ttt
![]() ![]() Join Date: May 2015
May or may not be what your wanting..my bushing aren't new but between my cab and frame is about a 1/2"..I can't stick my finger in the gap..my truck only has 26, 000 verified miles on it and my bushings look to be in good shape..just keep everything below the top of the frame and you won't have any problems
I stripped this truck for the drivetrain and front crossmember. Is this the heat shield you mean? It was close to the floor. I couldn't have got a box end on the bolts for the heat shield. Again not new mounts but they were in fairly good shape.
-Cody |
The wire you see across the top of the shield is an added 2 wire that went to some big switched lights on the back bumper
-Cody |
Mines a 81 and didn't have that shield..or a cat..any reason why your running cats..I didn't put any on my LS swap...maybe ga may make you do it I'm guessing..
Thanks everyone! Exactly what I needed.
I gave up on the "running the lines over the frame rail" idea after your responses. Just not enough room. Wound up drilling some holes in the frame rails and ran the lines through there. Looks much better now. As for cats, I wanted to do an entire emissions legal swap. Not that Georgia requires it, but one day my daughter may take it to college in a state that looks for such things. So I thought, better safe than sorry. Thank y'all again for the info. I'll post pics soon.
