Old 08-25-2016, 07:39 PM   #1
ck5566
Heatre Core Matieral
I have heard different opinions on the type of Material or Materials used for the heater cores in our trucks like Copper and or Copper Brass. Any body out there know what they were made of? thanks in advance
ck5566 is offline   Reply With Quote
Old 08-25-2016, 08:34 PM   #2
In The Ten Ring
Re: Heatre Core Matieral
Someone correct me if I'm wrong but the original cores were copper and brass. Modern radiators (including heater cores) are aluminum or aluminum and plastic.
My original heater core had a leak that according to the radiator shop could not be patched so I had them find me a copper and brass replacement.
I think Classic Industries carries copper and brass heater cores, according to a catalog I have.
In The Ten Ring is offline   Reply With Quote
Old 08-26-2016, 12:49 AM   #3
FirstOwner69
FirstOwner69's Avatar
I just bought an APDI/PRO copper/brass heater core from Rock Auto for my A/C truck. It looks just like the one from Classic Industries for about 1/2 the price ($46). I haven't installed it yet.
However, the APDI/PRO for the non A/C trucks looks like aluminum.
FirstOwner69 is offline   Reply With Quote
Old 08-26-2016, 01:27 AM   #4
CastIron
CastIron's Avatar
I replaced my leaking original earlier this year with an all aluminum one. It seems to work fine so far. The inlet and outlet tubes do seem a little more flexible than the original however. All the newer cars I've worked on use all aluminum cores, and they seem to last a long time. I would have no worries using either style personally.
CastIron is offline   Reply With Quote
Old 08-26-2016, 01:30 AM   #5
ck5566
I don't have A/C so wont do me any good there. I also seen Rock Auto having them and I was going to call and ask what material its made with but haven't did so yet.
Old 08-26-2016, 11:52 AM   #6
davepl
davepl's Avatar
My original Harrison unit was copper-brass, as was the repro unit I replaced it with. The repro was much thinner, I should have had my original re-cored (or inspected, it could be fine). In other words, the repros aren't anywhere near as substantial.
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 08-26-2016, 07:48 PM   #7
ck5566
Thinner, are saying it being not the (I think) 2 1/2" wide core Original Harrisons, most what I have found in the repop's being in the range of Under 2" wide core?
Old 08-27-2016, 01:42 AM   #8
In The Ten Ring
OK, good to know, thanks. I kept my original, the leak couldn't be fixed but the rad. shop guy found me one (also copper/brass). I might get my original recored then and stash it away.
I think I'll get my original radiator recored also and stash it away as well, when I have more funds.
Old 08-27-2016, 10:59 AM   #9
davepl
davepl's Avatar
Sorry I don't have a measured dimension for either, but to get the retaining brackets to work I had to shim it with a piece of wood, so I wouldn't be surprised if the repro is 1/2 to 1" thinner than the original.
Old 08-27-2016, 11:42 AM   #10
ck5566
I think what I have read from others here that the width of the repops are thinner and yes a Shimming method is needed to make them work. There's a couple of companies/catalog places that have Copper/Brass Cores but will call and ask what the dimensions are. I have called a few Radiators Shops to see if they can re-core them and all answers so far are NO. So the hunt goes on & on & on.
Old 08-27-2016, 12:12 PM   #11
davepl
davepl's Avatar
Then I guess I don't feel so bad that I didn't get mine recored! I still have my original, and it didn't leak, but it's 40 years old, so they're a bit of a time bomb by that age...
Old 08-27-2016, 01:11 PM   #12
ck5566
Your are probably right on the Time Bomb if past owners Only Used Water. Anti Freeze does add a little lubricant to the system I think
Old 08-27-2016, 02:44 PM   #13
Jarvis-69 GMC 1500CK
Im able to pick one up for 50$ from my local parts store for a 69 GMC 1500.
Do not know the details on it, but its apparently a new reproduction part.
Jarvis-69 GMC 1500CK is offline   Reply With Quote
Old 08-27-2016, 03:48 PM   #14
ck5566
There is a few places out there that sell repops' but the thing is they don't measure up to a proper fit, Too thin. Original is 2.5" thick & repop's are 2" and under. Repop's typically $45 to some times north of $65
Old 08-27-2016, 06:19 PM   #15
RodnRudy
RodnRudy's Avatar
I bought this one for my 68, fit perfect and is the same dimensions as original Harrison.
https://www.npdlink.com/store/produc...64-100664.html
Phil
"Money is only a tool to create and achieve what you want most in life"
PayPal: rodnrudy@comcast.net
RodnRudy is offline   Reply With Quote
Old 08-27-2016, 09:30 PM   #16
ck5566
Did the two top n bottom round rod Brackets fit without any kind of shimming or things like that? You know fit like a Glove. Huh
Old 08-28-2016, 07:40 AM   #17
RodnRudy
RodnRudy's Avatar
No shimming, it was a nice snug fit. I used the gasket that goes around the opening with no problem also.
Make sure your brackets are positioned correctly, they only go one way.
Phil
Old 08-28-2016, 10:28 AM   #18
ck5566
Wow one out of 10,000 repop parts that fit amazing. Thanks Phil
