08-29-2016, 11:08 PM | #1 |
Rear End, What am I?
Can just by looking at a rear end (3rd member) tell you what it is like a Dana 60,44's, or the standard GM rear ends? And does it matter if having Trailing Arms or with Leaf Springs determine what it is?
08-29-2016, 11:32 PM | #2 |
All about them K’s
Re: Rear End, What am I?
Your model of truck will help a lot in narrowing this down. If it's a half ton it's likely a 12 bolt gm, but there are some light duty semi floating Dana 60s around. The gm will have 12 bolts holding the diff cover on. If it's a 3/4 ton it's likely an eaton ho 52 which is identifiable by a removable 3rd member. It could also be an hd Dana 60. Both will be full floating rears but only the eaton will have a removable 3rd member.
I don't know as much about the 1 tons but I do know they should have and ho72 which is mostly the same as the 52. I think the Dana 70 was a possibility as well but I'm not positive. This is all speaking in Chevys. Gmcs primarily with the 3/4 ton trucks had Dana 60s.
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne: 5” lift, 35’s, front dana 60 blah blah blah… http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB: 4” lift 33”s… in a million pieces http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 35x12.5x20’s Last edited by 57taskforce; 08-29-2016 at 11:41 PM. |
08-30-2016, 12:34 AM | #3 |
The Older Generation
The Dana 44's and 60's will have it cast into the rear webbing where the arrow is pointing.... This is a 60. LockDoc
08-30-2016, 12:26 PM | #4 |
Here is mine, if needed I can get more pics. Truck was Originally a 68 C10 6 cyl, 3OTT, coils on all 4 corners. Doing the one wheel up & rotating tire around Twice comes around 3 3/4 turns being a 3.73 ratio.
The truck now has a SBC (305) & 700R4 and a hole lot of PAST OWNERS ideas on what to put on it just to keep it running **THAT** is slowly coming off & going back to mostly a Stock form but "A" (350) will replace the 305 some day. Last edited by ck5566; 08-30-2016 at 12:33 PM. |
08-30-2016, 12:45 PM | #5 |
12 bolt
Gary 72 SWB 4x4 My 72 SWB Build http://67-72chevytrucks.com/vboard/s...d.php?t=259859 |
08-30-2016, 12:48 PM | #6 |
GM Corporate 12 Bolt would be my vote.
08-31-2016, 01:28 AM | #7 |
How can you tell what ratio is in it? I've got a '67 SWB with a 6-cyl and 3-ott. I'd LOVE to get more speed out of it. 60 is about all she's got, without over-revving.
08-31-2016, 02:56 AM | #8 | ||
I am betting on it having 4.11's or 4.56's but it also could maybe have had the trans replaced with another or the gears changed out to give you a real STUMP PULLER! Do you go through the gears real fast like maybe close too 10 mph in 1st & 20 mph in 2nd & 40 mph in 3rd ? these are just a guess's for the mph's. Last edited by ck5566; 08-31-2016 at 03:23 AM. |
