#26 |
![]() Join Date: Jun 2012
Re: 1972 Medium Blue Highlander Blazer Resto
Ill watch this one
United States Marine Corps 2000-2011 Iraq and Afghanistan veteran Just living life now and enjoying it and my wife, daughter and son ![]() |
#27 |
Carpe manana
![]() ![]() Join Date: Dec 2010
The interior is almost totally gutted now. Soon I'll move onto pulling the front clip/motor/tranny/tcase. Wanted to share some interesting observations. First, I tried unsuccessfully to remove the paint over the blue door VIN decal so as to confirm the build month, which I suspected was either January or February 1972 as it was sold new in early March of that year. One of the seat backs and the dash pad had the following date codes that strongly support February as the build month. January 28, 1972 fell on a Friday.
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 ![]() |
#28 |
Carpe manana
Some quirks: the K5 had a second rear carpet strip in place of the correct front carpet strip (as mentioned earlier) and it looks as if the rear seat arm rests are both for the same side.
#29 |
Carpe manana
Swapped a single wall top for the original double wall and it fits well - no rust on the windshield frame.
#30 |
Carpe manana
In doing the top swap I noticed two differing styles of seal about the hinges used to attach the lift gate to the top.
1) Style one makes use of rubber grommets only with no brackets/trim plates or screws - this is the only style I found depicted in the factory assembly manual on a cursory search (top rows first pic). 2) Style two makes use of metal brackets/trim plates with underlying gaskets affixed to the lift gate and top by two trim screws at each site (bottom rows first pic). Wonder why the change from one style to the other? I'll have to investigate what style is reproduced.
#31 |
Carpe manana
Want to share some p/n's for some still available GM parts: rubber gas filler hose, rubber door grommets, vent tubes for differentials etc., and the AC divert box that typically has the busted flapper.
EDIT: The discontinued 1972-only door plates #20393850 that go between the panels and the window cranks/door handles are still in stock (20 plus) at Hubbard Chevrolet in Monticello, IN 574.583.7121 but asking ~$8 apiece (cost ~$4 list is ~$12). T.hanks for following along!
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 ![]() Last edited by DeadheadNM; 07-22-2016 at 01:29 PM. Reason: added |
#32 |
![]() Join Date: May 2011
I'm along for the ride. I have seen both types of hinge seals also but never really tried to figure it out. It would be interesting to know if the hinge bolt covers with the bent lips is only on one or the other also. I wonder if it is a single wall double wall think.
#33 |
I'm trying....
![]() Join Date: Oct 2013
I love the quirks. I wouldn't try and "correct" them either. Put it back like she came. I think you can find a truck to justify all four combinations of carpet strip installations from the factory. I think they used what they had. As a rule I love Midnight or Daytona Blue on Chevrolet trucks, but it's nice to see that Hawaiian starting to peek back through.
Great info on the OEM/NOS parts Pete. You are always blazing the trail. This is the perfect vehicle for you. Can't wait for what's ahead. P.S. The dash inspection tag is neat too. My brother was born the day before.
1970 Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=645076 1969 K10 SWB CST http://67-72chevytrucks.com/vboard/s...52#post8520352 1971 K20 Z84 https://67-72chevytrucks.com/vboard/...90#post9047290 1946 B.F. Avery Model A Tractor http://67-72chevytrucks.com/vboard/s...55#post8292555 "Sometimes I wonder if zander208 was even real..." |
#34 | ||
Carpe manana
I removed the fuel tank, front bumper, and and the inner fenders. Thank goodness for PB blaster and an impact wrench. The front wheel studs/lug nuts differ in size left to right. Posting misc pics of the fuel tank, fuel lines, and attachment hardware for reference. The tank is in great shape - not sure if OEM but has a stamped circle surrounding a big letter "A" on the top (hard to photograph).
#35 |
Carpe manana
For the purists: the OEM clamps for the rubber fuel lines were originally painted yellow - almost an ochre color. The frame clamps to support the metal fuel lines are orange. The colors are tough to accurately expose.
#36 |
Carpe manana
One hard line that runs along on the top of the LH frame forward to the fuel tank is not shown on the above photo but I've tried to depict it below (first pic).
The ground wire for the tank sending unit is shown - it was affixed to the rear crossmember with a bolt and two star washers at midline.
#37 |
I'm trying....
Great info Pete. Thanks for taking the time to document. Invaluable.
#38 | |
#39 |
Nice progress! I'm glad your tank is in good shape. The pictures are great. The three vent tubes most have been routed differently between years. They were under on the opposite side on my 71 and had a bracket that held the lines in place.
#40 |
Isn't yours a 2 wd that might make the difference if I remember correct on my 71 4x4 it was routed the same as Pete's but I could be wrong.
#41 |
Carpe manana
Brian I recall seeing a pic of the bracket you describe - Dwayne may be correct in that the difference is 2wd vs 4wd or maybe for the 72 MY the lines were changed. My green 72 blazer has the same set-up for the tank lines as my blue blazer. Brian do recall if your sending unit had a single outlet or two?
#42 |
Carpe manana
More slow progress. I'm dismantling and documenting everything at and forward from the cowl. I'll post some example pics of the various OEM screws used under the hood and other miscellaneous example pics.
For the bolt/screws I've only indicated the wrench size not pitch etc. but I did try to describe whether a captured washer was present, the number needed, and finish. EDIT: To clarify, the caption on one photo below erroneously indicated that there are three bolts to secure ground straps to the rad support. In fact, there are only two straps to the rad support and another from the forward harness mounts to the RH fender.
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 ![]() Last edited by DeadheadNM; 09-01-2016 at 08:34 AM. |
#43 |
Carpe manana
More pics
EDIT: To clarify, the bolts shown under "Upper Rad Support" affix the upper radiator brackets to the rad support itself.
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 ![]() Last edited by DeadheadNM; 09-01-2016 at 08:56 AM. Reason: added |
#44 |
Carpe manana
Pile of spare bolts off to receive black phosphate plating together with a set of hood hinges and hood latches. Also having some spare parts clear zinc plated.
Pic of a complete set of AC brackets for a SBC WITH the CA A.I.R emissions brackets (2) included.
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 ![]() Last edited by DeadheadNM; 09-01-2016 at 08:53 AM. |
#45 |
Wow Pete, wish I had this a month ago. This is absolutely awesome and a real asset. Thanks so much for taking the time to post all of this. I know it is time consuming.
Jeff. '72 Blazer K5 "Camshaft opinions are like belly buttons; everyone has one and no two are alike" My Blazer Build: http://67-72chevytrucks.com/vboard/s...d.php?t=626752 My Engine Build: http://67-72chevytrucks.com/vboard/s...d.php?t=637336 |
#46 |
Carpe manana
Here are pics of the OEM battery cables for reference - included the attachment bolt with its star washer for the negative attachment at the RH cylinder head. The positive cable is affixed to the RH frame with two clamps: the more anterior clamp is rubberized, the rear clamp is all metal and had the bolt threads directed upward.
#47 | |
Carpe manana
#48 |
That is awesome!!! It will be a great reference when I start to put mine together. Thanks in advance, Dwayne.
#49 |
I miss this truck.
Holy scmoly... The detail makes my head spin.
'07 GMC Acadia SLT. Sweet ride. '08 Crew Cab Z-71 short bed. Really like this truck A LOT. |
#50 |
Great work Pete! I'll stop by after 3 today and visit.
Posted via Mobile Device |
