Old 09-01-2016, 02:52 PM   #1
wlf89
69 c/10 lwb fleetside
wlf89's Avatar
67 brake light trouble
everything has been working good untill the other day and with headlights on brake lights and turn signals are real dim or not working at all. turn headlights off and brake lights and signals are strong. is this a grounding issue? if so where are all the ground locations?
69 lwb fleetside
67 swb fleetside
(2) 72 lwb fleetside
50 swb no bed
65 impala ss
65 1 ton flatbed
wlf89 is offline   Reply With Quote
Old 09-01-2016, 09:12 PM   #2
LockDoc
The Older Generation
LockDoc's Avatar
Re: 67 brake light trouble
This is kind of a long read but it covers the grounding pretty well.
http://67-72chevytrucks.com/vboard/s...d.php?t=422234
I would say that's what your problem is....
LockDoc
Leon
Old 09-02-2016, 12:16 AM   #3
leftybass209
leftybass209's Avatar
That's a pretty classic grounding symptom. Do you know how to do a voltage drop test with a multimeter?
If so, start at your negative battery cable, and check it to determine what shape the cable is in. Then, go through every ground strap, cleaning them with a wire brush, flap wheel, grinder, or whatever you have.
I have some bolt on ground straps, but I also used some clip on ground straps from early 90's Ford Explorers. A few extra ground straps doesn't hurt.
Also, the link provided by Lockdoc is a good read, but you'll notice a couple comments suggesting making your own out of a piece of wire and a couple terminals. While that does work, the goal is flexibility and longevity with grounding. Ground straps are used because they provide a flexible connection that is resistant to rigidity, and breakage.
leftybass209 is offline   Reply With Quote
