Old 09-05-2016, 07:04 AM   #1
pvienneau
pvienneau's Avatar
Ring and Pinion gear change question
Anyone know of any reason not to rebuild a third member with 3:55 gear and pinion out of a parts truck AD rear end and then use it in another truck? This way I can do all the work with minimum time running truck is off the road. Both are 1949 AD Pick up trucks. I guess question is are the rear end parts all the same with the exception of the left and right bearings which are machined at time of trucks birth.
Pat
1949 unmolested Indy Farm Deluxe AD
1949 Standard 4 speed http://67-72chevytrucks.com/vboard/s...d.php?t=581544
pvienneau is offline   Reply With Quote
Old 09-05-2016, 09:08 AM   #2
solidaxel
solidaxel's Avatar
Re: Ring and Pinion gear change question
Why not change the whole rear axle
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 09-05-2016, 09:21 AM   #3
pvienneau
pvienneau's Avatar
Do you mean take the rear end off the parts truck which is in great shape and do it complete rebuild then through it on the running truck? That's what I was thinking to do.
Pat
Old 09-05-2016, 09:26 AM   #4
solidaxel
solidaxel's Avatar
Are you sure the ratio is 3:55 on a AD truck, do they both have closed drive shaft?
LS 3 4L70E
Old 09-05-2016, 09:30 AM   #5
pvienneau
pvienneau's Avatar
I bought the kit to upgrade rear end to 3:55 and both trucks have the enclosed drive shaft. One is a deluxe with 3 on tree and the parts truck is a 5 speed standard. All the driveshafts must be same length irrelevant of the tranny. Before I do any rebuild I will take measurements.
Pat
Old 09-05-2016, 02:09 PM   #6
Jemezcrusher
5 speed standard?
Jemezcrusher is offline   Reply With Quote
Old 09-05-2016, 04:11 PM   #7
pvienneau
pvienneau's Avatar
Sorry 4 speed on the floor.
Pat
Old 09-05-2016, 04:25 PM   #8
Jemezcrusher
Guess it is technically a 5 speed. Four forward, one reverse. Standard
Old 09-05-2016, 04:32 PM   #9
MotherTrucker
MotherTrucker's Avatar
No need to remove the torque tube from the truck to upgrade to the 3.55 gears.
Deve has a great tech article on how to do it here.....
http://www.devestechnet.com/home/DifferentialOverhaul
MotherTrucker is offline   Reply With Quote
Old 09-05-2016, 04:33 PM   #10
pvienneau
pvienneau's Avatar
Standard meaning no chrome and not with 5 windows.
Pat
