Old 09-05-2016, 01:29 PM   #1
61K10
61K10's Avatar
221 transfer case any experts?
having problems adjusting my t/f case shift linkage. seams to (at times) to not want to go all the way into 2hi. (not hitting the floor) seems like 4hi gear is rubbing not completely disengaged. Make an offal squealing sound. any thoughts? also when i had it on jack stands (all for wheels off the ground) running in 4hi the ft driveshaft is bent. could see it moving up and down some. new r&p in ft axle and new u-joints. No dents are scrape marks on d/s. It never ends lol!
1961 chevy K10
my build is------------61K10 build
61K10 is offline   Reply With Quote
Old 09-06-2016, 01:57 AM   #2
'63GENIII
'63GENIII's Avatar
Re: 221 transfer case any experts?
Mine was always really difficult to shift. Usually would go from 2wd to 4wd just fine. Getting it back out was a different story. I would have to get under the truck with a large screwdriver or small pryer. The shifter and linkage was somewhat cobbled together by the p.o. I also attributed it to the straight cut gears. Never did figure it out before the 205 went in. Still need linkage and a front shaft for the 205 at this point.
Im not sure how the shift detents are set up in the 221 but remember thinking that they may have had burs that needed filing or an adjustment. That was just a thought before i gave up on it. Im no expert past putting a set of seals and bushings on that case.
Chris
'63 k15 long step
Vortec 7.4 - L29 Blackbear tune, Five 0 Motorsports injectors, Chris Straub Cam, NV4500, divorced 205
52" front and 63" rear spring swap
D44 / 14bff - disc axles
Milemarker 9K and 10.5K hydraulic winches
63" & B52 Spring Install http://67-72chevytrucks.com/vboard/s...ng+swap+thread
NV4500 Reverse Build Thread http://67-72chevytrucks.com/vboard/s...=reverse+build
L29 - 7.4 Vortec Build http://67-72chevytrucks.com/vboard/s...&highlight=L29
'63GENIII is offline   Reply With Quote
